Morgan Aero 8
9 members (RichardV6, Laurens, Mike D, RedThree, Alistair, JMcL, MartinB60, sbarracl, Image), 327 guests, and 24 robots.
+8Rich 91
John V6 49
Posts837,985
Page 3 of 3 1 2 3
Originally Posted by Franky
Dear Will or The Customer,
yes the original Z8 steering wheel has an airbag and yes the Z8 steering wheel in the Aeromax has an airbag as well.
Regards Frank
fascinating - thanks Frank
Will
Formerly Aero S5 #80
Goodwood Drifter
Goodwood Drifter
a Coupe is way cooler than an Aeromax
but that split-window design and the story of the Prince and... make the 'Max so special
Steven
now: +fourLM62
Here is a RHD Aero Series 1 in Germany. Of course you don't know much without inspection, test drive and history, but the price seems attractive if the car is ok. It looks like a normal dealer for slightly better everyday cars who would rather make a quick turnover than charge a top price.
https://suchen.mobile.de/fahrzeuge/...-cb7a-c9a2-90ea-8fb59eebcac4&ref=srp
- unusual rear diffuser on there too Heinz; looks as though it could be a 'one off ' design....
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Looks more like a cheap sheet metal trim. For the exhaust system, I don't know if only one pipe per side was original on the early Aeros. As I said, one would have to look at it in the metal.
Originally Posted by TheCustomer
Do you know if the Z8 wheel had an airbag?
If I recall right the Z8 has a 2 stages airbag, while the original Raid steering wheel has a 1 stage ones.
That means, for instance, that in CH you would need some very good friend, to have it registered for the MFK (MOT).
Technically the change is doable, though.
Yes Heinz, single pipes either side was the usual choice, this one looks like it's had the Librands Sports 4 outlet system fitted.
David
Aero S4
Page 3 of 3 1 2 3
