12 members (sbarracl, James B W, Pipmac, Morganmike, DJC, IcePack, PaulV, Ian Wegg, Simon, AlyMatt, TalkMorgan, aerotaff),
224
36
Topics49,914
Posts838,179
Posts: 3 |
I have a '65 Plus 4 with a Moss transmission. I cannot move the clutch as the collar assembly is stuck. Does anyone have a remedy other than pulling out the tranny to repair? Can I remove the bolt that holds the spring and fill the tunnel with PB Blaster or Liquid Wrench to soak the collar over night? How about heating the collar area or slot with a propane torch?
Posts: 614 Likes: 1
Posts: 614 Likes: 1 |
Ask Billy Bellinger from JB Sports Engineering
Morgan 4/4 Sport Competition
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Tricky one
The only sure way to do the job properly is to remove the transmission, gearbox from rear, engine and bell housing to front.
Then you can access the clutch sleeve easily , get it freed off, cleaned up and the bell housing machined and sleeved to prevent it happening again.
You can try all sorts of release agents into every orifice on the bell housing and gentle heat, but ( I hope I am wrong) with only a limited chance of success.
If you do decide to remove the transmission , come back on here as there are several tips that you easily make use of , to future proof the work
Good luck
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
On my 69+8 the sliding pin broke in the slot .I managed to remove the transmission tunnel and gear lever.,then the bolts to the gearbox mounts and the bolts to the bellhousing . finally I managed to roll the gearbox upside down.luckiy the bolt thread tapped out. It was a lot ove work but less than taking the engine and box out.
Posts: 3 |
Thanks to all for your suggestions! I will they them all pull the tranny as my last resort. Regards.
Posts: 3 |
Update: Removing the grease fitting at the top collar location and squirting PB Blaster did not work after soaking a few days. Thanks to "sprinty", I contacted Billy Bellinger and he agreed to trying to warm up the tube. Using my propane torch worked to free up the collar. Rinsed out using brake cleaner via the grease fitting opening and re-greased it. Thanks all for your input.
