8 members (BHV, John V6, banbury, JohnHarris, TBM, Haggispeed, Carbuilder, David_E), 152 guests, and 34 robots.
+8Rich 96
John V6 50
Topics49,901
Posts838,045
Page 39 of 164 1 2 37 38 39 40 41 163 164
I used a Dremel Richard.
Craig Jezz
I replaced my wiper blades for new from Melvyn Rutter Ltd.
Two * 7" and one * 6"
Will test out this weekend.
Previous originals were struggling.
Roadster V6 3.0L 2005
I got the first leaf spring back in today. Compared to what saw online I put the U-bolts on first, though I left them a little loose for now. Then I attached the fronts. Finally the rear with 2 helpers. I rigged up a strap around the end of the springs and a board as a lever. Then had one helper stand on it to pull the leaf springs down adjusting the link as it came down to avoid the wires. I had 2 washers between the link and the body, so I glued them together. I held them in place while the other helper worked the bolt in. Hopefully I can get the other side together tomorrow.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Well done that seems a clever way to get there.
This worked out very well, and should work as well for the other side.
73 4/4 "Henry A"
60 MGA
Just loaded her up for the trip down to Cranfield for the new hood.
Got a definite 'and what do you think you're doing with my car!' from the Petrolhead Cat 😄
I'm at AWs on Tuesday. I'll keep an eye out
Due to drop it off at opening time on Wednesday ... from here that means heading off tomorrow to get part way. If I make really good time I might try and get them to let me drop it off Tuesday before closing ... worth a try.
Nice Work....
Thanks! I'd like to say it was easy, but it was far from it. I think the order is the key. And getting the nuts on the U-bolts is good to do while there is still plenty of room. Finish tightening them when everything else is complete.
One question I have, I've read that I should torque the U-bolts nuts to 30 ft lbs. I only have a conventional torque wrench that I would normally put a socket on, but that won't fit between the chassis and the springs. Any suggestions?
73 4/4 "Henry A"
60 MGA
