6 members (Beard, TBM, JohnHarris, Rudolf, Ruut Bianchi, Guern), 174 guests, and 148 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,285
Smed., Spanner Juggler
Page 3 of 3 1 2 3
Montegue #774150 08/04/23 06:07 PM
Originally Posted by Montegue
In theory, coil springs will produce a better ride than leaf springs, but that's the only advantage I can see over leaf springs with well chosen dampers and a Panhard rod, however, for me the elephant in the room for the SSL five link setup is that it fails to remove the biggest compromise of all, the super heavy and rigid beam axle. This big old lump of cast iron unsprung mass remains so I couldn't help feeling £5k plus is a hell of a lot of money to shell out for what very likely would just amount to slightly better coil sprung ride quality, and maybe not even that if I could just find the right leaf spring and damper combination,
FABULOUS post Montegue. One of the best I have had the pleasure of on a Morgan dg for a LONG time. Very
impressive.
The Morgan's flexing frame is a key and unknowable component of trad suspension and each is different, not only
from the start, but as they adapt to different equipment configurations, type and frequency of usage and even
driving styles. Each trad can be tweaked to be quite wonderful, but there is no one-size-fits all. I spend 10 years
driving almost identical Morgans with the same suspension setup and tyres. They were not the same.
Link suspensions and coil springs FOCUS suspension forces, not exactly healthy for a flimsy, wonderful ladder
frame. Leaf spread the forces far more, marrying well with the frame to produce the legendary ride moggers adore.
I think leaf springs are infinitely more complex, but sadly not tweakable as yet. I believe that can be resolved one
day.
Thank you for your post.
Lorne
PaulyG #774169 09/04/23 06:12 AM
Thanks for your kind comments Lorne.
PaulyG #774192 09/04/23 12:24 PM
PaulyG Offline OP
Does the adjustable shaft of the panhard rod have to sit perfectly parallel to the solid cross member? Or can the part attached to the leaf spring be an inch or two away? I assume parallel is ideal, but I can't imagine the forces are so great that 1 or 2 inches off would make a difference.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #774199 09/04/23 01:09 PM
TBM Online Content
Angled is fine, The photo attached is from Williams Morgan.
PaulyG #774231 09/04/23 05:52 PM
Good news is that once fitted the rod adjustment can be used to centralise the axle to chassis if needed, and within small limits. I think mine (5 link) was found to be 10mm out of true to chassis but correcting upset the symmetry of tyres to bodywork so the final correction was split. This modest error showed up when I later had the front toe laser checked. As suspected from the handling some toe out was found and adjusted to a smidgeon of toe in.
PaulyG #774291 10/04/23 12:22 PM
PaulyG Offline OP
Thank you both. Good information.
73 4/4 "Henry A"
60 MGA
DaveK #774714 13/04/23 09:26 PM
Originally Posted by OZ 4/4
Originally Posted by griffo
I agree. I fiitted the asymetric "anti tramp" springs from BCC on my 2014 turbo Plus 4 after the original Morgan springs virtually collapsed. They have been brilliant, despite the hike in power to 280 bhp.
Now there's a surprise........
To sort Monty's handling I knew the dreadful original factory rear leaf springs had to go, shockingly they'd gone soft in just 10,000 miles so they clearly weren't correctly tempered from new!!!
You were lucky you got 10,000 miles. Mine were gone before the car even left the factory, after we got home Borgi replaced them with a set of 5 leaf springs: way too hard!
Originally Posted by DaveK
When I looked into this during my rebuild I binned the leaf springs and went for SSL suspension front and back. It has improved the ride 100%. It's a big outlay but if your MOG is a keeper.
Me too smile
Any one want a set of 5 leaf springs with about 10K on them?
Gambalunga #775348 22/04/23 08:57 AM
Where on earth did Morgan source these dreadful leaf springs from anyway, and what steel were they made from?
My guess is India, where there are lots of leaf spring manufacturers who will sell you something that looks like an automotive leaf spring, but is actually made from very poor quality steel. The metallurgy of spring steel is a huge subject, but if my original Morgan factory springs were anything to go by I suspect they were simply made from a really low grade cheap carbon steel that was never tempered correctly, if at all!
A quality automotive leaf spring should be made from modern EN45, or at least old school AISI 5160 chrome alloy steel that should also be oil quenched at 829C, then tempered at 430c – 700c. Where different yield strengths and formability characteristics are required the carbon and manganese content of the steel can be varied to give AISI 1050, 1074, 1075 and 1095 although AISI 1070 is considered a good compromise.
I do wonder how many trads are out still running their Morgan factory springs, I strongly suspect the AVO rear dampers that came with Monty were fitted by the original owner in a misguided attempt to solve his rear suspension complaint, but the truth is the bigger underlying issue that was never addressed was the springs.
The AVO’s on Monty were of course totally overwhelmed by the original leaves and were completely worn out in short order due to the ridiculous amount of work they were forced to do trying to control Morgan’s so called springs, both top bushes on these rear AVOs were also completely destroyed due to the constant and brutal pounding forces they had to endure.
Perhaps Morgan used the same spring supplier for many years as I think it's highly likely the GDI Plus 4 JayEmm drove in this review suffered the same issue.
https://www.youtube.com/watch?v=TaZiWVU1vRw
After talking for a few minutes about the suspension's lack of composure, around the 7 mins 30 second point in the video he makes a big play of what happens when he encounters a bump in the road. I'd wager the dampers used by Morgan were also rather basic and combined with their awful weak springs conspired to deliver what looks like a harsh bottoming out experience in this review and JayEmm's overall criticism of the Plus 4's ride and handling.
That's a real shame, because with the right springs and dampers all these issues go away, OK it's still a beam axle on leaf springs so the design is never going to deliver Lotus ride quality and handling, but my Plus 4 running BCC antti-tramp springs and the excellent Bilsteins from SSL really does ride and handle very well indeed, if say you compare it with other vehicles that run the same setup like say an MGB or Triumph TR3.
In my limited experience it seems clear a properly tempered pair of springs that are not too stiff paired with and controlled by a quality and well matched damper set are the best investments to improve the trad Morgan experience and its driving dynamics, revealingly the BCC antti-tramp springs were described to me by Techniques morgan as "softer than what we normally fit ourselves" when they fitted them, and I believe this is part of the secret to Monty's excellent ride quality.
I've long been an advocate of the suspension recipe that combines compliant springs controlled by a firm damper of quality construction with well matched valving to that compliant spring, the Bilsteins dampers I chose certainly tick this box and come with the added benefit of really big progressive shaped bump stops made from the correct material made for the job.
When I first took possession of Monty it was clear the rear springs had gone horribly soft, dangerously so in fact, so I knew the first thing the car needed was a decent pair of properly tempered leaves, I then studied the rear suspension design and concluded the following:l
1. To me the first big challenge to overcome is that the dampers have an awful lot of work to do controlling the rise and fall of such a heavy lump of cast iron, the rear axle. To achieve this I concluded investing in the very best damper set I could lay my hands on was top of the priority list and once the awful factory springs had been replaced.
2. The second flaw in the rear suspension design is it's lack of available travel, there really isn't much you can do to solve this issue so I concluded I needed a setup that uses every last mm of available travel without experiencing the harsh bottoming out issues that becomes a risk when you're using every mm available. I can certainly see why with weak Morgan factory springs paired to their very basic dampers offering next to no bump stop system will result in the kind of unresolved handling JayEmm reported and the harsh botting out episode we all witnessed in his YouTube review.
If JayEmm had just driven the same car with a set of the properly tempered and compliant BCC antti-tramp springs paired with the firm and well valved Bilsteins I suspect he would have given a very different opinion of that GDI Plus 4's ride and handling. The car probably still would have bottomed out due to the lack of suspension travel, but with the big progressive bump stops on the Bilsteins he just wouldn't have felt it. You see that's the thing about bump stops, it doesn't matter if it's a set of Roger's design or if the bump stop is incorporated within the damper as with my Bilsteins, if they're designed correctly they should completely eliminate that harsh bottoming out feeling that travels up your spine, don't get me wrong the system is still bottoming out, it's just you don't feel it wink
The final addition I would strongly recommend is a Panhard rod, on Monty this definitely solved the considerable and quite alarming lateral axle movement for a very reasonable cost, after fitting there was no loss of ride quality at all either so I’d say fitting a well adjusted Panhard rod is a no-brainer upgrade for every trad Morgan owner.
Montegue #775502 23/04/23 03:02 PM
Another great post! However, I have not heard of any MMC leaf spring from India..though there was a long period when I did not track the MMC.
Perhaps I can add some perspective for you. At least during my time of Morgan ownership (30 years), the MMC has always been parsimonious
in their component sourcing with trads. (Nothing terribly wrong with that if you prioritize researching and choosing the best product first and then
try to find less expensive way of purchasing it). However, in their hard years after the Aero launches 2002, the MMC also became very slow payers,
something new for them after almost 100 years.
When that happens suppliers try to find ways of compensating. The leaf springs of the traditional supplier of many decades started failing. For example,
I have 5 springs on a 2002 and they are STILL good, showing a drop of 1/4" at the rear. However, in 2005-2007, during the complete restoration
of another, almost identical mog in the UK, I went through 3 sets of 5ers, each collapsing unacceptably after a 3000 mile trip! I solved that by switching
to the newer GMP 4 leafs, (sourced other than the MMC) which I and the later buyers after me swear by to this day! (17 years). Yet my Help Box was soon
regularly filled with failing GMPs since. I believe the MMC has tried others, all with the same eventual result.
This bothers me constantly on behalf of trad owners. I agree with you completely. These leaf failures vastly degrade what should be a sublime experience
in comfort. Because of their flexing frames, leaf springs are IDEAL for Morgan trads. Link suspensions focuses forces...an inevitable no-no for such frames.
But if one cannot find proper leaf springs, what other choice is there? I began scouring North America, where the long trucking distances puts leaf spring
makers every 50 miles. ALL experts agree with you. It is a question of poor steel quality. You certainly have my vote! I also very much like the
way you (& Dan White) dealt with tramp and costless with no prejudice to comfort!!!
However, there is a couple of minor related problems. Stock trad axle saddle plates and stock u-bolts are not strong enough. They shear. The ubolts also
stretch, requiring replacements at each service. I use graded 7/16 and a thicker graded plates. I sourced them from Peter Mulberry back when
Axle ubolts& plates. As well, the MMC axle centering pins used to be (perhaps still are) ungraded. They shear, forcing one, eventually, to drive home sideways! doh At the price, it is wise precaution to use graded ones. Easy to swap in when changing leaf springs. Makes a potential problem disappear forever. My Morgans are a little silly in the power department (I try to keep them detuned down to 292bhp on Rob Wells' wise advice). So any component that can survive my Morgan for decades can survive any trad.
If you are selling heftier plates and ubolts already..can you indicate that and I will add it to the Gomog recommendation for your company. You are a very welcome
addition to the short list of great new Morgan suppliers.
Lorne
Page 3 of 3 1 2 3
