0 members (), 390 guests, and 32 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
Page 3 of 3 1 2 3
kiwi100 Offline OP
Thank you so much Grumpy2, I can see that they are quite simple to make and seem to be perfect for what I want to achieve.
I presume you compressed them before you tried to install them.
THANK YOU ALL SO VERY MUCH for all your expertise and interest in the problem.
This has to be one of the friendliest group of car enthusiasts ever.
Kind Regards and Happy Miles.
Kiwi, I compressed the springs to remove them and to reinstall. Really glad I did too, the amount of compression needed on my car to remove the springs was quite surprising and I fear that using the ‘blanket of Hope’ method I’d have ended up with (at best) a spring flying uncontrollably around the wheel arch. Like I said above I had to compress the spring about 20mm to reinsert it!
Good luck with you endeavours.
I’ve been reading this thread with fond memories. I think enough time has passed (64 years) for me to relate what I did without too much embarrassment. I was 19 at the time and the 1947 4/4 S1, Standard engine, was my second car, bought for £35. The front suspension needed replacement, but in the days before TM or the ‘net and no other Morgan owner in my Lancs town – how to get information or parts? With the car in pieces and a trip to Lifes by bus or train too complicated, F.H. Douglas came to my aid but posing a question by letter and waiting for a reply typically took a week to 10 days. Eventually, the parts were obtained, but then how to do it.
I used a screw jack, extended, placed under the bottom plate, and held in place using mother’s (soon to be ex-) washing line looped under the jack and over the chassis, removed the nut and wound down the jack. A friend who worked at English Electric, building Canberras, did the bearings and everything went back together the same way.
Later, I used to drive 30 miles to Southport just to go past Lifes and look in the window, a white +4 Supersports I remember. My 4/4, FUO 919, got me going on a lifelong enthusiasm. My granny gave me a proper toolbox and a pair of white overalls. I went on to change the clutch, rebuild the steering box with oversize nut, make a complete new wiring loom in all correct colours and many other jobs on many other cars, but it all started with those kingpins and bushes.
Originally Posted by Grumpy2
These are the very simple spring compressors I made to safely remove and reinstall the main springs. I didn't fancy the 'blanket of hope' method and with approx 20mm compression I feel I was right to compress the springs in a controlled way. I'd never have got my main springs back in without these compressors. And that was with the rebound springs removed using the two stud method outline above. Perhaps springs were incorrect, too long or too strong, I don't know but these worked for me on at least two occasions. Made from 25mm square tubing .
Nice work Grumpy!!
kiwi100 Offline OP
Ha Ha JMcL. what we take for granted now with the interwebby. Thankfully most of our classic cars were more plentiful back then and more owners did their own work. I always were able to find another owner not too far away to assist with advice and also returned the same when asked.
White overalls for a Morgan "now there is a site"
Happy Miles
Bryan.
Page 3 of 3 1 2 3
