1 members (Saxonian), 263 guests, and 30 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
Originally Posted by Leroy
I followed the diagram above when I installed my steering bearings, but found trying to get the main spring back in impossible, so had to compress them with straps.
How odd! What happened exactly? The same method has been followed by many hundreds for 40-50 years with great success. It is the
safest method for the job.
Did you measure the length of your new main springs before installing them?
I admire your ingenuity!
Lorne
The SSL instructions on disassembling front suspension prior to fitting their RS kit go to great lengths explaining there will be residual tension left in the main spring after the rebound spring has been removed and stub axle is resting on lower cross arm. They suggest covering same in blankets to avoid damage to bodywork when you pull it out from its seat. In reality I found virtually no energy left in springs and both easily pulled out with no drama. I can imagine fitting new plain main springs especially if higher rate, and/or fitting steering bearings for the first time may provide a little challenge though. Tyre levers spring to mind innocent
Lorne
I kept the original springs, which will have increased the compression needed to get it back in, just too much for me to get in by hand.
2004 Series 1 Roadster
Scroll down this page as check out the shovel method
https://madaboutmorgans.com/remove-and-reinstall-morgan-spindles/
Our own Ron Gardner here in the states put this together. I used a stainless-steel garden spade as a rusty one won't let the spring move. I also drilled a small hole in the end so I could slip a screwdriver through the top to make it more secure until the spring was almost in place.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Yes, I can vouch for the spade method. I used my wife’s stainless spade, which is a bit smaller, and put a smear of grease on the surface to help with the “slide”.
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Lorne
Thank you Leroy. So they were longer with the rungs further apart..?
The MMC has been playing with front spring rates for different reasons for the last two decades, primarily in an effort
to make the front "softer" which effects the front handling A LOT..especially as the cars have become heavier. That is
why I asked you for the length. For more powerful Morgan models, I recommend the original rates. Your Series I
Roadster falls into that category. (I very much like that Roadster model). They used to call then, probably still do!
'Plus Four main springs. Plus Fours and Plus Eights used them for decades. Picture below. They have the original +4
and +8 140 rate.
The MMC embraced the eMog fad for steering races (those bearing thingies at the bottom of the main springs) in late
2007. I am not sure if or how they adjusted the springs for added pre-load. If so, I wonder which springs you were sent.
A lower or higher rate changes the car's comportment in turns. I find the 140s crisper handling than the mild wallowing
one I sense with lower rates in a more powerful Morgan like yours (or my car). If you feel an unwelcome change, merely
swapping Main Springs in or out is not too much of a chore, as you know now. Merely fiddly.
Good luck.
Lorne
These are the very simple spring compressors I made to safely remove and reinstall the main springs. I didn't fancy the 'blanket of hope' method and with approx 20mm compression I feel I was right to compress the springs in a controlled way. I'd never have got my main springs back in without these compressors. And that was with the rebound springs removed using the two stud method outline above. Perhaps springs were incorrect, too long or too strong, I don't know but these worked for me on at least two occasions. Made from 25mm square tubing .
Lorne
and +8 140 rate.
Good luck.
Lorne
My springs are labelled plus 8, so I guess they have a higher compression rate.
wink That is not how things work on Pickersleigh. Labelling is whimsical. After 50+ years, they merely changed
the label but not the spring rate. https://morgan-kent.com/product/main-coil-spring-4tr-8-black-05-91/ Plus 4s
for early Plus 8s are now Plus 8s for early(TR) Plus 4s.
There was a point where some racers tried main springs with rates higher than 140s.180s IIRC. IMHO a VERY
bad idea. Many Moggers inexplicably assume that firmer suspensions are better. But cars handle better and
go faster when their wheels are on the road rather than hopping over it. The Factory tried to reverse that trend
in the early 2000s.
Be well.
L.
That would be my approach, a far safer one.
