7 members (SailingTom2, Rainer Duell, JohnHarris, Sir Percival, RichardV6, Mark+4, sospan),
295
Topics49,899
Posts838,028
Posts: 10 |
The 2012 onward Morgan Three Wheeler (M3W) Registry
(use the number under the right seat and the VIN (the last 3 digits) and not the number of the wooden frame)
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA 202103 -1299 - December '17 Sports Blue/Honey Leather, Paul C Melbourne Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP
sold: Aeromax009/M3W/RoadsterV6/444seater
Posts: 99 Likes: 5
Posts: 99 Likes: 5 |
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Melbourne Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP sold
M3W 2017 Sport blue.
Posts: 10 |
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Melbourne Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
Posts: 8 |
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Melbourne Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
Posts: 99 Likes: 5
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Adelaide, Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W sold Aug ‘18. Car recently rebuilt with new chassis by present owner and Bleazey centa mods. Tim W getting PEMBLETON V SPORT. 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Adelaide, Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
Posts: 36 Likes: 3
Posts: 36 Likes: 3 |
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W sold Aug ‘18. Car recently rebuilt with new chassis by present owner and Bleazey centa mods. Tim W getting PEMBLETON V SPORT. 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 2027 - 2027 - Apr '16 - Feierstarter - Sport Green/Black Leather (SmallTransmissionTunnel by MorganPark), bought used Apr '23 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Adelaide, Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
2016 M3W
Posts: 1,947 |
The 2012 onward Morgan Three Wheeler (M3W) Registry
(use the number under the right seat and the VIN (the last 3 digits) and not the number of the wooden frame)
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W sold Aug ‘18. Car recently rebuilt with new chassis by present owner and Bleazey centa mods. Tim W getting PEMBLETON V SPORT. 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator SOLD 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 2027 - 2027 - Apr '16 - Feierstarter - Sport Green/Black Leather (SmallTransmissionTunnel by MorganPark), bought used Apr '23 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Adelaide, Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
Posts: 23 |
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W sold Aug ‘18. Car recently rebuilt with new chassis by present owner and Bleazey centa mods. Tim W getting PEMBLETON V SPORT. 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator SOLD 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 47054 - 2333 - Mar ‘15 - Metallic Orange/Black Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 2027 - 2027 - Apr '16 - Feierstarter - Sport Green/Black Leather (SmallTransmissionTunnel by MorganPark), bought used Apr '23 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Adelaide, Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
Posts: 5 |
under VIN seat 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium) 0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0080 - 2056 - Apr '12 - Jonathan G 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack. 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W sold Aug ‘18. Car recently rebuilt with new chassis by present owner and Bleazey centa mods. Tim W getting PEMBLETON V SPORT. 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0706 - xxxx - Apr '13 - Kean - Superdry 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator SOLD 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 47054 - 2333 - Mar ‘15 - Metallic Orange/Black Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 2027 - 2027 - Apr '16 - Feierstarter - Sport Green/Black Leather (SmallTransmissionTunnel by MorganPark), bought used Apr '23 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Adelaide, Australia 46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA 0586 xxxx - Mar 2013 SBP - Grey
