Topics48,341
Posts813,001
Posts: 23 |
I need help in locating two frame mounts for a 1600 cross flow, mine are gone on a restoration car and I do not have even measurments to make new. I would like to find them ready made but if anyone has photos or a diagram to make new it would help. These are the mounts from the frame to the engine. The car is a 67 4/4 if that helps, perhaps someone has a junk frame with the mounts still bolted. Thanks. Dale
Posts: 7 |
I have a set and can take some photos for you. Send me your email address and I'll send them to you off line. I'm assuming you are referring to the long blade-like devices that bolt to the frame. The actual motor mount which has the rubber cushion is a Lotus Elan item.
Robert rhauge@comcast.net
Zetec & T9 in early 4/4
Posts: 23 |
Thank You for the response, My email is TheLakers@toast.net If possible, would you be able to send me some measurments also? Thanks again, I was getting desperate. Dale
Posts: 462 |
The mounts are different for Morgans with 1500 (pre-crossflow) and 1600 (crossflow) Kent engines. A 1967 4/4 would have the 1500. Do you have the earlier car with the later engine? Lots of Morgans had such an engine swap.
Perhaps Melvyn Rutter can help with the mounts for the 1600 cc.
Frank
1967 4/4 1500 Comp. 1935 Super Sports Barrelback
Posts: 23 |
Thanks for the info, yes I do have the later engine, I have been trying to get the information or the mounts for the past 6 months. I can try Ruter. Dale
