8 members (nick w, Mike D, Hamwich, John V6, KennethM, Dek, thelastgizmo, Image), 382 guests, and 23 robots.
+8Rich 101
John V6 63
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,196
Georgetoad, woolfie
Page 13 of 173 1 2 11 12 13 14 15 172 173
5 of the GEG made it to the Rumburgh Buck. A great cross country drive via lots of twisties. The pub is a CAMRA pub and the N E Suffolk CAMRA pub of the year.
Oub website link
A nice pint of Suffolk Bitter , fish , chips & mushy peas plus blackberry & apple crumble iwth ice cream for £21.
Five of the four cars. Belle being the odd one out parking wise
Other desserts were available
I cannot stress how good this dog friendly pub was. The Mauldons Suffolk Pride was excellent ditto the food which is served seven days a week and very reasonably priced by today's standards.
Thanks to Fox Terrier for suggestion. I will be back for one.
Similar experience Dave when the top shock mount plate broke. Didn't really suspect anything on the 50 mile journey home following a single clunk over severe bump. Fortuitous that greasing was due and noticed the break whilst on the ramp straight after.
A good advert for not using a nylock nut twice maybe although I suspect we all do at least once innocent
The thing is, we discuss the merits of various dampers for Morgans, and yet I've now completed two long journeys with a damper disconnected, and aside from the odd hard bottoming out, you just can't tell.
Can anyone suggest a supplier of bushes for the top of the front dampers please?
grin2
Dave, try Dan at SSL
Edit, if you can wait until tomorrow evening, I'll check my store, I'm sure I've got a pair of unused OE shocks
Thanks Jon, but I've ordered a new pair. I did still have the OE's from the Plus 4 until a few months ago!
thumbs
Originally Posted by AlyMatt
Just come back from a trip to the Rioja and Picos areas of N Spain - mostly fabulous windy mountain roads etc. Car behaved perfectly and ticked over 15,000 miles whilst there.
Used some of Pete Clarke's ideas from the April and May 2021 Miscellany editions for some ideas which gave us a couple of excellent drives. So thanks to Pete if he reads this forum. Can't seem to get one of the pics to rotate...frustrating..
Great photos....
Originally Posted by IvorMog
Richard, I'm with Doug on this.
Just checked my old Bilstein and there are no spacers, only rubber bushes.
Also, in the SSL instructions there is a note not to over tighten the top damper nut.
I always thought the top mounts should be left with some flex in them.I.e. "only nipped up and not crushed" (SSL's words, not mine)
Could over tightening cause the top plate problems?
Agree regarding only just nipping up top rubbers
This is a photo of the top rubbers from Spax front shocks and there is definitely a spacer visible
Thanks Jon although a little confused as to why you would not tighten down fully onto metal spacers. Your pic illustrates my earlier post regarding the SSL supplied Spax shocks, allowing a limited light compression of rubbers when fully tightened down.
Bob and Doug, the SSL instructions re not overtightening top rubbers appear to refer to the Bilsteins supplied by them in earlier RS kits and likely not updated for the Spax adjustable gas shocks now offered. The advice is still relevant to lower eye mount rubbers though which can be overtightened.
Given the universal front damper top mount plate has an enlarged hole to accommodate the metal spacers, I imagine the Bilstein's and maybe others have mount rubbers with a shoulder to fit within this hole and limit the shock spindle sliding around within? The spacer solution makes so much more sense to me though and cannot see why fully tightened they would cause my mount plate to break, as you can see the rubbers do not appear to be over compressed.
Having driven over 400 miles back from Ullapool, with one front damper disconnected over every conceivable type of road and surface, what I do know now is that your choice of damper on a Trad, certainly at the front, will make little difference to how your Trad drives.
The single setting Spax on my 2016 Plus 4 were very good. I couldn't resist changing them for AVOs, but the difference really is marginal. Whether they are better is subjective, and what really is "better"?
Although I've ordered replacement parts for the AVO, I decided to fit some Spax gas adjustable on the front. Another probably futile experiment but we'll see.
The bottom mounting..the AVOs have two bushes with a steel tube inside. The fixing stub has a raised section beyond the threads, so I tighten the nylock until the penny washer seats on the raised section.
The Spax just have two bushes, without a steel insert
At the top, the AVOs have a dished washer, then a bush with a raised lip to locate in the hole in the bracket on the crosshead. Next another bush with a raised lip then a dished washer on top, plus nut.
The Spax have two smaller but thicker bushes, each has a dished washer both sides, and one of each washer is shaped to locate in the fixing hole. Interestingly the Spax have a nut and locknut, rather than a nylock. There is no metal sleeve in the bushes supplied.
I'll nip the nuts up until they look right and feel right on the spanner.
That's a long-winded way of saying it really won't make a lot of difference.
The Spax have 28 clicks, so I'm starting out at 12. See how we go.
Now I'm tempted to fit Spax adjustables to the rear........ grin2
Richard, I'm not saying that over tightening definitively did break the top plate but over tightening the top bush will put extra stress into the top plate.
If you think of the movement of the damper, the bottom mount attached to the stub axle moves through a significant arc when steering. The top mount is fixed to the cross head so it can't move.
As the bottom mount swings around the arc, if the top mount is tight it will put a bending stress into that top plate and also into the rod of the damper.
All of course IMHO and ready to be proven wrong.
Also, The wording of the SSL instructions specifically mentions the Spax damper in the same paragraph as the not crushing statement.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
All I would add to that is that if you watch the movement of the damper when steering lock is applied, the piston rod rotates in the damper body. So probably not much stress on the rod, but a significant stress is put through the bushes, top and bottom. Even initial fitting distorts the bushes, and it's the same at the rear.
The biggest crashes I hear are from potholes on corners where the suspension goes fully compressed and gives a single loud bang. Usually from the outside wheel. The question here is what causes the bang. It sounds metal to metal, but that could only be from spring binding unless there's compromised contact elsewhere. The top if the kingpin has that simple rubber tube bumpstop, but that shouldn't bang hard. It could be the damper bottoming out, and if that happens the shock will travel into the lower mounting on the stub, and the top plate. But even then the bushes will take the load.
After 15 years I still can't figure out what causes that occasional hard bang on corners. idea
Not today, but it will now be a bit quicker to get the Morgan out. The driveway obstacle left for a new home this morning.
Tomorrow should be heading for the AV8 cafe at Kemble (Cotswold) airport as a Spitfire is supposed to be running passenger flights. We have a table booked for lunch, so with the nice weather, taking the Morgan seems to make sense. smile
