5 members (jbk, RichardV6, aerotaff, Ruut Bianchi, Pyewacket), 236 guests, and 30 robots.
+8Rich 102
John V6 59
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,177
Georgetoad, woolfie
Some techies advise if it's a modernish Mog with an ECU, only turn the key to position 2 ( ignition on) and then be patient...wait until the fuel pump primes, if it has a tacho some do a sort of test sweep to full revs and back that you can clearly see, only when this is done then start the engine
Bit like a modern TV, press to swop channel as the BBC pulls a spoiler with the GP result swear and it takes several seconds to react...all that electrowizardry ain't as fast as we think
I usually wait for the immobiliser light to stop flashing but not always. It really should not make any difference. If the engine turns over the immobiliser is off so the only other possibility is a second or two delay for the fuel to the injectors to arrive at pressure, in that case the engine should crank a couple of turns more till fuel arrives. The ECU would also require a couple of microseconds to read the sensors: again that should not stop the engine from starting.
My guess is either that you arrived at a very unusual set of parameters that triggered a bug in the ECU program or that you have a sensor that had temporarily lost contact, or giving a reading that was outside normal parameters, to the ECU. By forcing it to start with easy start spray you somehow triggered the system back to normallty.
I would think that the most likely culprit would be the MAF (Mass Air Flow) sensor or the connections to it.
