1 members (Saxonian), 299 guests, and 33 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
Originally Posted by meabh
Afternoon all from a mixed bag of weather in France.
I was greasing the front suspension and inspecting the wheels today, when I noticed that the tyres, at 10000 miles and four years old have 6mm of tread depth on the outer groove and 4mm on the inner, on both front wheels. There are no other visible signs of tyre wear and I don't know how long this has been going on. This years control technique did not flag it. Could the team advise please. Thank you.
On my ‘86 4/4 this would be an indication of sliding bush wear causing the tracking to go out
Simon
2002 4/4
2021 Audi A1 sport
meabh Offline OP
Simon,
Thank you. I wondered about that too. My roadster now has 27000 miles on the clock. The nine o'clock, six o'clock test doesn't produce any movement though that would flag king pin wear but the previous owner might have changed the pins for hard chrome although he only did two or three thou in it.
Hi, If the wear is even on the inside of both tyres then its definitely the tracking! Its running too much toe out but not by much looking at the wear! Try a half turn on each track rod to adjust the tyres to run more toe in. That is assuming your steering wheel is running straight when driving. first check for wear or damage to steering/suspension parts pay particular attention to track rod ends, rack and hub both, and fastenings at the rack. I've found that even when tracked properly you can get tyre wear and I usually end up making micro adjustments whilst keeping an eye on the wear pattern by accurate tyre measurement. also are your pressures too high? are you running over inflated to make the steering easier? this can lift the tyre onto the inner edges and scrub on cornering!
Easy to check for bush/kingpin wear with both front wheels jacked off the ground. Hold tyre at 6 and 12 'o clock and alternately push at top and pull at bottom then reverse. You will easily feel wear if any, except perhaps just after greasing. If it's only just felt, not recently greased and it's not loose wheel bearings (unlikely) then you have 5,000 miles or more before renewal really needed. Such minimal wear may not be picked up by annual test either.
meabh Offline OP
Sewin and Richard,
Thank you. I will try half a turn. I checked pressures again and they are 22psi all round, and there is the tiniest of movement at the 12/six o'clock position which disappeared when the spinners were given a really good thump. I'll see if I can find a good tyre fitter this coming week to check the tracking.
Recommend finding a tyre shop that offers laser tracking. If you really want to try adjusting youself first remember that outer steering rod ends have right hand thread but inner near rack left hand.
jbk Offline
That is is absolutely right Richard, however there was (presumably) a batch of steering rods that had the same thread both ends, don't ask me how I know. still possible to do the tracking but more of a faf. if the tracking man is taking longer than you think, thats why. at least rod used on a 93 plus 4 and plus 8.
1993 T16 +4 Lancia Blue.
That's crazy but strangely believable. Guess it would require you cracking the TRE taper to wind steering rod in or out at one end only, re-assembling then checking doh
jbk Offline
Thats right Richard , the young lad on the laser learnt a lot that day. I imaging the bloke on the lathe who threaded the rod made the left handers in the morning and the right handers after lunch, if mine was unique and not a batch it was probably in the wrong pile at lunchtime.
jbk Offline
is this what you call a thread drift?
