7 members (JoeSpeetjens, Paul F, Zach, Steve +8, RedThree, Strathaven, JohnHarris),
258
57
Topics49,917
Posts838,230
Posts: 27,853 Likes: 767
Posts: 27,853 Likes: 767 |
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
Changed the Diff oil, flushed the clutch fluid (can't bleed a 3.7) and stripped the rear brakes on the Roadster today
Posts: 8,705 Likes: 416
Posts: 8,705 Likes: 416 |
Pedal overhaul now complete after rebuild and replacement with superior marine grade stainless M8 clevis forks, new pins and previously missing washers. Took the opportunity to adjust pedal positions a tad as well, checking that n/c brake light switch adjustment correct. ![[Linked Image]](https://i.imgur.com/JS60G0Q.jpg) ![[Linked Image]](https://i.imgur.com/qt6NexE.jpg) Lower pic shows 10mm brake m/cyl rod reducing to M8 thread matching that of clutch rod. All went smoothly after help from  in attaching support pillar nuts from underneath. Couldn't see any good reason why factory put the right hand side bolts in upside down so fitted mine matching from above. Something of a faff either way as you are working against brake pedal spring tension even when unhooked from pedal itself.
No I had to give her a stool to sit on with a clean cover so she didn't spoil her dress, then adjust ramp so she was working at eye level
Well done Richard. Very smart.
Nice one Richard
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
Val deserves a big reward for that 🍷
And you’ve done quite well yourself of course 🍺
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 51 Likes: 17
Posts: 51 Likes: 17 |
Fixed the silent horn (again) today. Last week was a dodgy crimp in the horn button. Today was a poor connection on the horn itself. Jobs coming up New door mirrors New door checks New door lock covers Find a sidescreen bag at a reasonable price as over £200 is outrageous. Currently chasing down a AustinHealey one.
2002 4/4 Zetec Indigo Blue purchased July 2023 my first Morgan
Posts: 6,680 Likes: 441
Posts: 6,680 Likes: 441 |
Find a sidescreen bag at a reasonable price as over £200 is outrageous. Currently chasing down a AustinHealey one. Try and find an independent car trimmer - my local bloke made one for me, cost £60.
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Couple of days ago, actually. I had a couple of badges that I wanted to put on the car, but there are already three on the front, so I made an aluminum bar for the rear. Thoughts? ![[Linked Image]](http://tm-img.com/images/2023/08/16/IMG_6076.md.jpeg)
