5 members (sbarracl, RichardV6, Image, MartinB60, JMcL), 309 guests, and 39 robots.
+8Rich 91
John V6 49
Posts837,985
4acker Offline OP
I took my radio of the car and fuse blow. Now the conitinious lighting of all four push switches is not working anymore. I heard that changing the module is not cheap. On the other hand it is made in THT technology and has standard parts. Is there someone in the Morgan world who is able to repair these modules?
BR
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Did you check the panel light fuse & the 2 radio fuses? The best diagram I could find is here, it might not be right for your car but the handbook should have a diagram
If you are talking of the PCB they can't be repaired. My pcb failed on my 2006 Roadster, I found with the lights on it all worked so wired the lights on permanently. There are 2 micro relays on the board one with the lights on one without.
Do your instruments light up with the lights on?
4acker Offline OP
The instruments light up with the lights. The light in the switch for the hazard flasher is completly not working. The other switches have no permanent light but are illuminated when turned on. One fuse for the radio was blown and replaced. The radio is working. So I think no other furse is defect,
Online NoMood
Check fuse 12, 7.5 amp which covers r/h side lights and dash illumination. Also fuse 17, 10 amp which covers radio permanent feed and courtesy lights. Neither would stop radio working completely.
Exactly Richard that was what I was trying to suggest.
