1 members (Taffmog), 289 guests, and 60 robots.
+8Rich 104
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,254
Smed., Spanner Juggler
Page 71 of 165 1 2 69 70 71 72 73 164 165
And Val's!!
Changed the Diff oil, flushed the clutch fluid (can't bleed a 3.7) and stripped the rear brakes on the Roadster today
Pedal overhaul now complete after rebuild and replacement with superior marine grade stainless M8 clevis forks, new pins and previously missing washers. Took the opportunity to adjust pedal positions a tad as well, checking that n/c brake light switch adjustment correct.
Lower pic shows 10mm brake m/cyl rod reducing to M8 thread matching that of clutch rod.
All went smoothly after help from swmbo in attaching support pillar nuts from underneath. Couldn't see any good reason why factory put the right hand side bolts in upside down so fitted mine matching from above. Something of a faff either way as you are working against brake pedal spring tension even when unhooked from pedal itself.
Originally Posted by John V6
And Val's!!
No I had to give her a stool to sit on with a clean cover so she didn't spoil her dress, then adjust ramp so she was working at eye level love
Well done Richard. Very smart.
Nice one Richard thumbs
Val deserves a big reward for that 🍷
And you’ve done quite well yourself of course 🍺
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Fixed the silent horn (again) today. Last week was a dodgy crimp in the horn button. Today was a poor connection on the horn itself.
Jobs coming up
New door mirrors
New door checks
New door lock covers
Find a sidescreen bag at a reasonable price as over £200 is outrageous. Currently chasing down a AustinHealey one.
2002 4/4 Zetec Indigo Blue purchased July 2023 my first Morgan
TBM Offline
Try and find an independent car trimmer - my local bloke made one for me, cost £60.
Couple of days ago, actually. I had a couple of badges that I wanted to put on the car, but there are already three on the front, so I made an aluminum bar for the rear. Thoughts?
