8 members (Bilymog, linklaw, DavidR, Strathaven, Bunny, Graham, G4FUJ, lez, TalkMorgan),
184
36
Topics49,906
Posts838,104
Posts: 378 |
Hi All, The indicators on the car - right hand ones- have given up and it looks like its the bulbs. Is there anyone who know how to get into the front and the rear ones to check them. On first looks it seems a major challenge ! Thanks T
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 8,700 Likes: 416
Posts: 8,700 Likes: 416 |
Unlikely front and rear indicator bulbs would have both blown. I guess the reduced load on right hand circuit might have inhibited the flasher unit though. If you can, check if front or rear give a brief flash when first selecting right indicators. The one that doesn't will be the bulb to check/replace.
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
I agree it would be odd for both to drop out at the same time due to bulbs, possible but odd, a surge on the line or grounding issue could pop them both perhaps. More likely a relay or switch on the column?
Hit the hazards and see what happens.
Yes it is a bit of a devil to get into the rears but the fronts should be accessible via the arch if you turn the wheels. IIRC I had an issue where the cable was being scuffed by the wheel and needed restraint but that might have been a different car with my memory.
Posts: 378 |
many thanks for the responses - I gave it a run yesterday and they all worked ok! Which is probably more annoying in some ways ! T
