1 members (Socalm3w), 423 guests, and 39 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Hi Gerhard, sorry to hear about your problem.
I also have a M16 +4 and no local workshops here in Australia. My car is back on the road again after many months. My problem was mostly a non starting issue and so replaced most of the sensors and ECU with no difference. Eventually when ordering another part, I also bought a new distributor cap, rotor arm and spark plug leads. When I put these on, the car has started and run again; as I put them on at the same time, I don't know which one was the problem but think possibly the distributor cap??
Of course, your car may be a totally different issue. Maybe also check the vacuum hoses around the plenum chamber, throttle body flange & air line to the ignition ECU in case of leaks.
There are some very good articles on the Gomog website and I have found a lot of the references to the Rover v8 are relevant to the M16 motor also. (some sensors are the same, also fuel pressure regulator)
I can send you some links to articles I found helpful if you want to send me your email.
Hope you can sort it out soon.
Regards, Col
+1 for checking for air leaks. The ECU will be affected by that. I the Haynes manual on the Rover 820 may help you .
This is the fault finding guide
Engine stalls
m Engine management system fault (Chapters 1 and 4).
m Vacuum leak at the inlet manifold or associated hoses (Chapters 1, 2 and 4).
m Fuel filter choked (Chapter 1).
m Fuel pump faulty or delivery pressure low (Chapter 4).
m Fuel tank vent blocked or fuel pipes restricted (Chapter 4).
Engine lacks power
m Incorrect ignition timing (Chapter 5).
m Timing belt incorrectly fitted or incorrectly tensioned (Chapter 2,
Part A or B).
m Uneven or low cylinder compressions (Chapter 2, Part A, B or C).
m Worn, faulty or incorrectly-gapped spark plugs (Chapter 1).
m Brakes binding (Chapters 1 and 9).
m Clutch slipping (Chapter 6).
m Automatic transmission fluid level incorrect (Chapter 1)
How old are the HT leads? The insulation could be breaking down as the car gets hot.
2025 MG ZS EV aka Trigger
Black Rat
Black Rat
My first thought Keith until I read the end of his first post.
Oops I missed that
Keith
2013 narrow bodied + 4 Ruby.
Hi there
I would go straight to the Rotor arm in the distributor.
There is a resistor or similar in the top that is known to cause this problem.
I have experience of this, get a new rotor arm
Ian.
Ian
Morgan Family 1929 ( KTW 1100cc )
Morgan S/S 1934
Morgan F4
M3W 2012
Morgan +4 T 1991
Water in the petrol tank from E10 petrol?
Thanks for your tips, I'll work them off as far as possible. Greeting Gerhard
