5 members (Graham, G4FUJ, Craig Jezz, Grumpy2, TBM, Krossek), 187 guests, and 45 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Both upper and lower grease nipples feed into the same grease reservoir so don't panic should you have managed to grease via the lower nipples.
There is also the possibility, as some have found, that the upper lube point is blind - i.e. not drilled.
Say Hi to Arwyn when you visit, he'll figure out exactly what is going on smile
1 member likes this: SwissMogFan
Now that Nick is a brilliant solution!
When buying my first Mog Phil at Allon Whites gave me tips on greasing. The main one was to lever up the damper blade bronze plate on the hub to see grease coming out in the gap. This showed two things.
Grease had gone in
It lubricated the plate/hub to help keep steering lighter.
I did mine at 1k miles max and with the hard chrome kingpins I had no wear problems over 40k+ miles. I used a pneumatic grease gun so easy to lever up the plate whilst triggering the grease gun. Turning the wheels left/right made access to the nipples easier. (Behave yourselves)
