0 members (), 275 guests, and 48 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
Contact M3WServices at Info@M3Wservices.com
They have bases in France and the UK but might be able to give you enough info to decide if a local dealer or garage could do the work.
Red Leader drive
Originally Posted by RHBigSmile
Thanks for the "diagnostics tool"! It is easily pushed when in gear... Not sure if the Bleazey conversion is available from the dealer or anybody else here in Norway. Anyway, thanks! To be continued! :-)
Or just operate the starter - if the starter 'whirls' then rollers failed.
Thanks Chris
You could get just the inner Centa rotor modified whilst engine is out for replacing the rollers - much more cost effective solution for you than sending the engine to PB.
You still need the hole put into the bell housing. You can then change the rollers without engine removal same as PB version.
I have carried out 5 of these rotor upgrades so far and no problems encountered - its a lot less involved than removing the complete Centa from the engine and avoids 'breaking' the connection between crankshaft and Centa and therefore the spline issue.
