9 members (MartO, JonathanLand, mph, DJC, Plus Four Guy, DaveW, Graham, G4FUJ, Zach, lez), 111 guests, and 139 robots.
+8Rich 103
John V6 66
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
First Morgan as it is now
by Strathaven, September 15
Topics49,931
Posts838,500
AlexCreasey
Page 1 of 5 1 2 3 4 5
#785308 11/09/23 08:50 AM
Gonze Offline OP
Having completed well over 10k miles in our MY22 PlusFour, I thought some members might find some interest in the top 20 modifications, gadgets and other tweaks that we’ve found most helpful on our various travels around Europe, to make the car slightly more practical. These are obviously a personal view and I’m sure some purists won’t like them all, also worth saying several I picked up through other posts on this forum - so thanks to other members who post these useful tips!
I’ve tried to loosely group these into similar categories below; some are dirt cheap, some simple DIY modifications, some technically a bit more complicated.
#1 Windbreaker
We DIY’ed a simple removable windbreaker out of some flyscreen mesh and elastic; it stretches over the headrests and makes a major difference to the wind turbulence.
[Linked Image] [Linked Image]
#2 Door Foam and D-seal strip
The amount of water that splashes in through the doors on the autobahn is quite phenominal - after various trips shoving socks and other things into the gaps, we eventually velcro-ed some foam and D-profile strips along each door - these are working a treat; no more water coming in and less wind noise with the hood up.
#3 Floor Mat
The box-weaver carpet under the driver pedals quickly gets destroyed by heal scuffing - Halfords sell a cheap rubber mat - about 30x40cm - we trimmed that to size and glued some wide velcro on the back of it. Has worked very well and can be replaced very cheaply and easily in the future.
#4 Drinks holders
I posted about this before <see link> but these two simple holders have been very practical for water bottles and coffee cups.
https://www.talkmorgan.com/ubbthreads.php/topics/715273/plusfour-cup-holders#Post715273
#5 Phone Holder
I also posted previously about this https://www.talkmorgan.com/ubbthreads.php/topics/731641/re-phone-holder#Post731641 but I’ve found this simple suction cup based approach works well. I had to tweak it a bit to get the stem the right length, but now seems pretty solid and phone can charge with a short usb lead.
#6 Tunai Button
These simple Bluetooth remote controls work really well - the holder has a rubber band to temporarily attach it to the wheel. It allows you to control volume and skip music tracks easily if you are playing through your phone to the car speakers.
#7 Fader Balance
The front to rear speaker balance in the car is very poor and the audio attenuates when you have stuff on the rear shelf - hence I inserted a fader control into the sound system. It is quite a complicated fix but I tried to post instructions previously:
https://www.talkmorgan.com/ubbthreads.php/topics/731648/re-front-speaker-sound-output#Post731648
The other thing this revealed to me was the space behind the speakers, which I used below for a storage compartment (#14).
The following four things are security related - in general I’m not over concerned on security for the car, but some of our travels have been very distant from countries that have dealers or suppliers of spare wheels - hence we’ve done these things:
#8 Lockable Fuel Cap
I posted previously about this https://www.talkmorgan.com/ubbthrea...fuel-filler-cap-for-plusfour#Post769648. It does seem a bit strange that the car is supplied without a lockable cap.
#9 Wheel Lock
The spare wheel is standardly secured with a very simple handle that can be removed by anyone when the car is parked - as in the photo above, I replaced this with some threaded studding and a wheel lock.
#10 Monimoto tracker
I’ve gone for a very simple tracker produced by Monimoto - it’s really designed for a motorcycle but works well for a Morgan. The device is battery powered - which lasts about a year, and just needs hiding behind a panel in the car. There is a dongle you attach to the car key holder and when the car moves, the Monimoto checks that the dongle is present, if it isn’t present it calls your mobile and then starts broadcasting it’s location to your phone. Very simple and (for a tracker) very cheap (from memory about £120 for the device and about £3 per month mobile subscription), also I like the way it can’t drain the car battery as it is not connected to the car electrics.
#11 Hawk Alarm
Probably the most involved thing I’ve done - but I’ve wired in a simple alarm into the vehicle. I went for a Hawk HA-240, but using only 3 sensors - two ultra-sonic sensors that are in the two footwells (see pic on #12 below), plus a bonnet release sensor protecting the alarm siren itself (see pic). There is also the blinking blue LED when the system is alarmed, which I’ve fed into the corner of the glove compartment.
#12 Battery Charger plug
Whilst doing the alarm I also installed a connector cable under the glove compartment, as a connection for the trickle charger - simpler than having to open the bonnet each time I garage the car. The cable is visible at the top of this photo secured on a retaining clip, along with one of the alarm ultrasonic sensors (to the left).
#13 Diving Bags & Kanulocks
Everyone will have their own views on luggage for the Plus Four - personally I find these 60L Gill Diving bags work well and most importantly keep clothes dry! We also found these lockable Kanulock straps which have wire in them to avoid anyone slashing the strap and removing the bags (think they are designed for surfboards, etc..).
[img]https://i.ibb.co/dLY2jMm/IMG-8309.jpg[/img] [img]https://i.ibb.co/q1FRt3b/IMG-8315.jpg[/img] [img]https://i.ibb.co/nnKMWCL/IMG-8316.jpg[/img]
#14 Storage Compartment
This might be my most controversial modification; but if you access the space where the rear speakers are, there is quite a lot of space there. Extending the speaker cables a bit, replacing the lower screws in to the rear shelf with some smaller gauge (removable) bolts and applying Velcro across the top edge means that panel becomes removable, or at least can be pulled forward to provide access. I’ve stored various tools in that space (warning triangle, wheel spinner remover, tyre inflator, etc..) all secured in neoprene pockets and themselves held down by Velcro to prevent rattles. It’s not super accessible, but for those occasional emergency situations it works well. (You just need to make absolutely sure the seat belts run properly through that space and aren’t impacted).
[img]https://i.ibb.co/Sx3GZ24/IMG-4882.jpg[/img] [img]https://i.ibb.co/xXg4w7Y/IMG-4881.jpg[/img] [img]https://i.ibb.co/2g8v24W/IMG-4880.jpg[/img] [img]https://i.ibb.co/7GwQjz6/IMG-4879.jpg[/img] [img]https://i.ibb.co/gZrKnbh/IMG-4878.jpg[/img]
#15 Mini Car Jack
Allied to the above storage compartment, I bought a smaller, lightweight jack (alca compact scissor jack) which stores more easily.
#16 MotoLita wheel
Bit of an indulgence but I went for a MotoLita wheel - dished such that the boss to hold it was smaller than the boss for the flat wheels. My dealer sourced and installed it. I think it looks much better than the standard “Toyota” one .. but that’s a personal view (you can see it on the #6 Tunai Button photo above. (BTW I discovered that in the cold some leather driving gloves really help grip a wooden wheel).
#17 Rear shelf cover
Super simple, but we tried all sorts of bags and arrangements for storing things on the rear shelf behind the seats .. we’ve ultimately concluded that a piece of black fabric (with a bit of velcro to hold it at the bottom back edge) is frankly the most simple and practical; when the vehicle is parked it covers up anything we have stored, and when we are driving you can easily grab coats, hats or other stuff you’ve stashed behind the seats.
#18 Added some Windscreen Wipers
I opted to upgrade the comedy ‘windscreen wipers’ which came with the vehicle - they obviously didn’t really do anything to divert water from the windscreen, but at least caused some amusement as two of them ended up falling off mid rainstorm (despite the dealer retightening them!), the first time the wiper fell onto the bonnet, the second time I lost the wiper completely. The new versions are much more robust, actually do the job of a windscreen wiper and haven’t fallen off (partly thanks to some loctite I applied).
[img]https://i.ibb.co/zN1R7c3/IMG-8306.jpg[/img]
#19 Roadworthy Wing Mirrors
The supplied wing mirrors I found extremely dangerous - maybe it was my height but with the hood up the blind spot to the side of the vehicle was huge. I went for the convex ones that were discussed in this post <post> they’ve been absolutely transformative and much much safer.
[img]https://i.ibb.co/dJYwQYD/IMG-8304.jpg[/img]
#20 Silicon for Windscreen
Much as we enjoyed the ‘charm’ of the rain coming around the edge of the wind screen and into the cabin (see photo, which also shows an original ‘windscreen wiper’ blade).. we finally opted to upgrade the car by applying a bit of silicon to the gaps that had been expertly left by the factory windscreen fitters.
[img]https://i.ibb.co/d6nSKfX/IMG-4186.jpg[/img]
5 members like this: Ale_72, 42w203, Morganstyle, DWil23, Alistair
Go se, some great tips here and many thanks for posting them. I particularly like the cup holders and the music control.
On item 13. I also use Kanu locks which are great. For luggage is use an ultra samsonite suitcase like this one. https://www.ebay.co.uk/itm/166313181702?hash=item26b909c206:g:5wIAAOSwosZk9PoW&amdata=enc%3AAQAIAAAAwHctSIS%2BtDN5Fr0tro5ALEe7iE9EByXr4CEYOm%2BbpoJTD01ujNV5gOS66Ny4nsPkrWtrosm4NXUt8jz8I6AybdUSpIaAuC5oEXkG7BPGMXejqJtgP%2FF3dGZ0%2B8iOoR46BWI8H9LlCXD4GydjnEcc1zBY6PMLm0LTiwzCLtX6tBZKMqGjj2uHVFQ%2F8krxV3hGPJYSrrWL3RGAquZR2PFVWbyGcAxV6GwKQtxH3bxC3xkexw0FA0Hm%2BiTFaHZcn4boxQ%3D%3D%7Ctkp%3ABk9SR8a0iL7QYg
They are hardcase lockable, have a rubber seal between the two half’s which keeps it waterproof and even wheels. I’m not sure the modern ones have the same seal so use my old one for the Morgan.
18 windscreen wipers , I have also had one fall off so will take a good look at this mod.
Gonze Offline OP
#18 - I got replacement wipers from https://morgan-kent.com/parts/ if you search for ‘wiper’ they have four different lengths for a CX, so you’ll need to measure each wiper blade (all 3 of mine were different lengths)
That's a brilliant list - thank you for taking the time to collate and share them all.
Please could you provide some more detail on the door foam and d-seal strip ? Exactly how did you affix them - did you glue the velcro to the frame etc?
I've experienced the same in bad weather and even worse when a large vehicle passes in the opposite direction - I was actually getting water on my glasses
Thanks!
1 member likes this: gaston
I am very interested too.
Well done Gonze, great post thumbs
It warms my ancient heart to know that cx owners are glueing bits of velcro and inventing storage areas...the future is in safe hands
Gonze Offline OP
Gaston and Neil, thanks for the questions about the #2 door seal. I used a roll of heavy duty 50mm wide Velcro tape with self adhesive on both sides (similar to screwfix code 4419P), that interlocking floor matting which is about 10mm thick (screwfix have similar stuff code: 338PV) and finally a roll of 10x12mm “Black Big-D Car Door Seal Strip Rubber Edge Sealing Trim Weatherstrip Soundproof” from eBay.
I looked from the rear wheel arch to see where the gaps were and trimmed three sections of foam to fit these gaps - one on the door, one on the side screens and a thin one up the edge of the window frame itself. Needs a bit of trial and error to fit their shape. The Velcro tape was then cut and used to stick the matting sections on - Velcro was stuck on the ridged “top side”of the mat, leaving the smoother underside visible.
Then I stuck the D strip onto the foam and around the bottom of the door (inside the existing seal). Again needs a bit of trial and error. On the rear window edge the foam stops about 2cm below the top corner, the D-strip about 2cm below the top of the foam (in fact on one window I ended up sticking another strip of D seal on top of the first one, again stopping about 2cm short of the first D-seal)
I’m not sure if you can see all this on the two photos I posted - let me know if you want more details or photos and I can try to do that next weekend.
Hi Gonze - that's brilliant thank you and thank you for the Screwfix references too! smile If you could post any other angles/pictures of the final fittings that would be great but the instructions are super.
Cheers
Neil
Thank you Gonzé.
