1 members (sezznowt), 405 guests, and 53 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
Georgetoad, woolfie
Page 73 of 165 1 2 71 72 73 74 75 164 165
Spent a worthwhile few minutes tightening the hinge brackets as a very helpful chap noticed at Shere on Sunday that both my doors had dropped ever so slightly and were ‘flexing’ on the hinges. 🤔😊
Originally Posted by Grumpy2
Removed the bonnet strap, never really got on with it, just seems to make opening the bonnet harder!
And they rub your paint off on the touch points frown
Just bought these brushes at the local Aldi. The slim brushes were one set, and the 2 large ones were another set. £6.99 per set. They should come in handy for getting the dirt from the wire wheel spokes. A bit of a bargain I thought.
2004 Series 1 Roadster
They do look like quite a bargain. I'm sure you will be careful of those metal ferrules which could scrape the polished parts (if you have stainless or chrome wire wheels).
Black Rat
Black Rat
I use Dragons Breath wheel cleaner, spray on hose off totally amazing no more fiddling with spokes.
Keith
2013 narrow bodied + 4 Ruby.
I must try that
Beware Autoglym wheel cleaner on your stainless rims…it etches into the protective coating and leaves stains that cannot be easily removed. Thankfully, I only tried it on the inside first. WD40 Seems to be the safest and best treatment.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Took the wheels off for a poke around and to grease the kingpins in preparation for the MOT next week. Centres appeared welded on again so went straight to the "heat with steam from a kettle before banging away with the centre nut spanner and mallet" method and they came undone very quickly. Everything looking ship-shape under there!
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
I made a mistake that necessitated the replacement of the throttle cable. I replaced a broken motor mount, which raised the left side of the engine and failed to notice that it resulted in the throttle cable resting on one of the header tubes. This caused both the inner and outer sleeves of the cable to melt. When I removed the old cable, I found that whoever installed the twin Webers used a non Morgan cable assembly and had made a square hole in the firewall and pedal bracket to accommodate it. Simple fix was to make a small adapter out of some aluminum plate with the correct size hole. And, yes, I zip tied the new cable up and off the header...
Very neat
