3 members (John Winn, JohnHarris, RedThree), 194 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
#786150 22/09/23 04:28 PM
Hi Guys
+8 1989 V8 Rover engine, Holley carbs fitted; no mogs; rad grille clear of badges etc.
I fill rad with 50/50 antifreeze and distilled water; new stat fitted; engine flushed thru 2ce.
Get into traffic and kenlowe kicks in....temp goes thru roof.
After 30-miles or son header tank of rad is empty - takes 1-2 litres to fill....expansion bottle no change in level
Suggestion as to problem please.
Are you sure that you put enough coolant in, did you measure it?
It's possible you have an air lock! The rad looks full but it may not be a full system.
If you are still topping up and have no leaks my guess is an airlock.
The older days we'd have left the radiator cap off (cold engine) and started it up and as it warmed up and the thermostat opened the water pump would push the coolant around and would force any air out and the coolant level would drop again. Then top up again and repeat.
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
Originally Posted by Rayplusfour
+8 1989 V8 Rover engine, Holley carbs fitted; no mogs; rad grille clear of badges etc. I fill rad with 50/50 antifreeze and distilled water; new stat fitted; engine flushed thru 2ce. Get into traffic and kenlowe kicks in....temp goes thru roof. After 30-miles or so header tank of rad is empty - takes 1-2 litres to fill....expansion bottle, no change in level
Forgive me, Ray. You gave an incomplete description of your set up. Which Holley? Intake Manifold? What rad type? What exhaust system, stock or aftermarket twin? Kenlowe model? Where do you have your pressure cap, on the rad or "expansion bottle"?
However, I do not know of any setup using a 1989 Morgan 3.5 on a Holley 390 (or 600) and a Kenlowe that would NOT boil over in slow traffic. 😂 Want to cure that? L.
P.S. "Ray +4".... New +8 purchase?
