1 members (Kolvites), 328 guests, and 45 robots.
+8Rich 93
John V6 49
Posts837,990
rockabilly john
Will Stotts #786199 23/09/23 05:55 PM
I recently installed a VDO 292mm with an extra 5mm cork gasket.
VDO 224-011-020-292G €151.38
292mm fits exactly with that gasket.
Please note that new versions are available.
It is important to observe the correct measurements.
The resistance of the new 292 VDO version corresponds to the original built-in 250 mm VDO.
The resistance of the new 292 - empty-full: 73.8 - 2.0 Ohm
The new 279 - the 280 no longer exists - version has a resistance of 70.3 Ohm, which can cause more errors.
The short experience I have:
It works very well and the accuracy of the tank reading has been greatly improved.
I would advise comparing the new value on the dashboard gauge with the actual amount of fuel in the tank and making a small table and using Excel to create some sort of graph.
One ant does not know anything, 2000 are a super-intelligent brain. That's like this helpful forum.
Will Stotts #786287 24/09/23 10:11 PM
I find taking the laptop to access my Excel spreadsheets for filling up a touch inconvenient as with the slide rule, the finger in the air and I've driven for a while so better fill up resistance method has worked well for the last 10 years.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
