Topics49,880
Posts837,762
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
Peter H, Many years ago I used to race karts and I used R for the two stroke mix. I did not like keeping the fuel for too long between meets so some often ended up in the car. Then cat converters came along so that had to stop. I was left with putting the fuel in the lawn mower! I did make that job a bit more enjoyable. John
Posts: 57 Likes: 14
Posts: 57 Likes: 14 |
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
How do you dose yourself Bruce, swallow or push em up?  Oooh Sailor
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
Back in the day used to tip R40 into the tank of my classic Triumph at about 50 to 1 and called it upper cylinder lubricant. Used to smell magnifico.
Chickened out of bestowing it on the Blade as didn’t fancy risk of gumming up the works.
Wouldn’t add it to the Mog for similar reason. Also vegetable oil doesn’t mix with mineral oil.
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 9,548 Likes: 133
Posts: 9,548 Likes: 133 |
My Plus8 was always close to the lambda upper limit on MOT tests. I used V-Power petrol regularly. One year I had been using E10 for a few fill-ups as no no E5 available, up to MOT time. That test came out lower for lambda. I am wondering if the extra ethanol helped. E5/ E10 were stated as “up to” content so no guarantee of how much at any one time so not the best assumption on effect. My mate took the cars for MOT as he was a tester. He advised trying Cataclean but no guarantee of effect. Another mate also suggested petrol from the big companies not small outlets/supermarkets as the market was based on cost of supply and additives cut back on to sell to these outlets for cost reduction. He was in international vehicle recovery ( including a lot of police work) and his contacts told him about the additives situation.
Posts: 8,688 Likes: 495
Posts: 8,688 Likes: 495 |
These things have been around in one form or another at least since I've been driving (and no doubt much longer!) ... never worked then either ... made a lot of black smoke when you first started after that made you think carbon was being shifted but did nowt inside your engine.
Those tablets you put in your battery to rejuvenate it were sh*te as well !! 😀
K Those would be Bat-aid, when I worked in the car spares industry we sold a lot of those
Posts: 3,700 Likes: 131
Posts: 3,700 Likes: 131 |
Those tablets you put in your battery to rejuvenate it were sh*te as well !! 😀 Those would be Bat-aid, when I worked in the car spares industry we sold a lot of those  In my impoverished early motoring days I bought more than one packet of those. I see they still make them, surprisingly. ![[Linked Image]](https://tm-img.com/images/2023/09/29/Bat-aid.jpeg) Also in my tool bag back then would be Radweld for water leaks and Easystart for cold mornings, both of these still on the shelves at Halfords today. I'm not sure about Radweld but Easystart definitely did the business.
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
I can go back further Ian. White of an egg for rad leaks and  's nylons as temporary fan belt.
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
I can go back further Ian. White of an egg for rad leaks and  's nylons as temporary fan belt. All very well but you try getting the off her!
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 28,906 Likes: 353
Posts: 28,906 Likes: 353 |
Radweld never worked on my first Land Rover. Eventually we took the rad out and had it brazed. EasyStart or the OZ equivalent: ![[Linked Image]](https://tm-img.com/images/2023/09/29/SYB350.png)
2 members like this:
Davetherave, +8Rich |
