5 members (Dek, JoeSpeetjens, Plus Four Guy, Morganmike, Mike D), 422 guests, and 92 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,757
#788639 24/10/23 01:04 PM
PH1954 Offline OP
Hi Guys thanks for your help with the Fuel system problem Does any body know of a short shift gear lever
PH1954 Offline OP
the short shift lever was for a 2004 aero 8 also require the Aluminium surround for gear lever and fly off hand brake
Paul,
you would do better posting this in the right section.
Paul . Librands used to do a kit a few years ago but several series 1 car's have the so called short shift. Most including myself removed the Bmw knob and cut the stick down to the size required. The Le mans gear knob was the prefered one available from Morgan or half price if you went the Ritchbrook route. I found the gear knob got really hot most early adopters will testify to this,When I bought my second series 1 the the stick was left as it was and i prefered the larger Bmw Knob your choice off course. Em
You can still have the kits made up by Librands, if you do a search (sorry I am in the middle of something otherwise I would) you will find a post from me explaining what you need and how to sort it all out from a year or two back.
Aero 8 GTN #11
PH1954 Offline OP
Thanks Guys Great info
Smile, it confuses them
On the S2 we got the shaft cut slightly shorter and the metal billiard ball knob fitted.
I like the short throw that you get as a result when changing.
Only issue is that you do need a bit of effort to push past the detent to get reverse, mind you the S2 has a different box to the S1 from memory.
Yes it is a different box.
