Topics49,908
Posts838,115
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
I went with Stack gauges and senders so not necessarily too similar. I can't remember which main power supply I used but have in-line fuses for each gauge and the backlights are run off the sidelight switch. Ive got a couple of other things that required earth connections so I also fitted a piece of brass to the frame of the fusebox with a good earth connection and several tapped holes with brass screws to get everything securely earthed and not just a bundle of overlapping connectors on to one fiddly bolt.
Posts: 72 |
Gordon
2013 M3W 1972 MGB Roaster 1967 Morris Mini Super Delux
