Very wise Brian
. Batteries are consumables. The most expensive batteries with the greatest longevity will ultimately only serve to prolong the stage where their performance is marginal in cold weather.
Well said Richard! After going through every silly expensive battery ever made I learned that only two things are important about Morgan batteries.
1. Place it where it best balances the car which is invariably in the rear axle compartment on the passenger side (unless your life partner is 15-25 kilos heavier than you are).
Do NOT let your Morgan's comportment by prejudiced by the MMC choice.
2. Choose a battery size that can be found at any factor/automobile supplier open on a Sunday and stick to it.
gmg
