8 members (RichardV6, Sir Percival, Burgundymog, TBM, KLASG, moggywills, Bishmog, Colin_Mackay), 215 guests, and 52 robots.
+8Rich 83
Luddite 50
Posts837,944
MUE Offline OP
Hello at all.
I need a new clutch for the Morgan 4+ 1998 2.0 T16.
With clutch I can take for the car? Is the Borg & Beck HK 9012 ok? Or you know an other product/manufaktor?
Best Regards
Sven
MUE Offline OP
Really nobody knows about this?
jbk Offline
Hi MUE, apologies that no one has responded to your question, presumably not many T16s have had clutches replaced?
can I suggest to look on Ebay for a Rover 820 clutch kit that will come up with alternative makes. presumably you are safe to choose a known make. good luck
1993 T16 +4 Lancia Blue.
Try Rimmer Bros .
Is it not the same as some Lotus Elise S2 as they also have this Rover engine ?
Dada,
Plus Six "Samantha" (the wooden witch)
https://www.elise-spares.com/index.php?route=product/product&path=99&product_id=143
Perhaps
Borg & Beck Clutch Kits clutch is suitable for all Rover engined elise models 118bhp through to 160BHP.
109,95£
Dada,
I thought the Elise had the K series Rover engine?
Costock, UK
Disco 5
jbk Offline
Correct Paul.
What clutch I can use for the car? Is the Borg & Beck HK 9012 ok? Or you know an other product/manufacturer? Sven
Sorry for the delay in responding, Sven.
AS A GENERAL RULE FOR THE FUTURE, Rover Plus 4s from 1988 to 2000) use the same bellhousing, remote assembly, clutch components and gearboxes (with the same ratios) as the Plus 8s from 1977 to 2004. That will make your sourcing easier.
For example, search "Rover Morgan Plus 8 clutch" on ebay.co.uk or amazon.co.uk.
However, the clutch slave only changed to a standard 2wd LR from 1994.
gmg
MUE Offline OP
Thank you for all answers. Top!
