1 members (Carbuilder), 122 guests, and 15 robots.
+8Rich 102
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
Peter1062
I think I picked up a stone under my belt it caused a cut in thedge of the belt. I'm wondering if having a nick in an otherwise excellent belt is really all that important.
In any event I would like to purchase another to have in stock.
Are the drive belts Morgan only, or can these belts be purchased elsewhere from a manufacturer??
Thank you for any guidance.
S&S part number 106 0353, available from a number of sources or from Morgan
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
I would think that a small nick in the belt won't be a big problem, they are very strong and some owners have had a hole punched through the belt with a stone without failure for many miles. Probably something you don't want to run with for ages though. As Roger says, they are available from a number of places but none particularly cheap, £250 -£300. Changing the belt is not a quick job either, swing arm removal required.
I have seen a belt ripped to half its width and still running okay.
So personally I wouldn't bother going through the hassle of changing the belt for a mere nick.
I had replaced the original aluminum sprocket with the Super Max which has a line of small bolts down the middle of the teeth all around. Some worked out and shredded the middle of the belt teeth. That happened over 20,000 miles ago. The belt still works. According to quite a few of the bikers I've talked with the belt should last up to 100,000 miles. They are damn strong. The other belt on the motor that drives the cams should go half of that if the case has been modified to help keep it cool.
The replacement schedule for the cambelt is now every 10,000 miles and some are struggling to last that long.
Red Leader drive
Cam belt gets changed every 3 years regardless of milage, I have 3 used ones as spares all in good condition. Used and serviceable is better than broken every time.
1 member likes this: gomog
For what it's worth, this late in the day, my 'Brooklands' had an 8mm hole in the drive belt when I purchased it five years ago. The MOT inspector draws my attention to it every year but it hasn't increased in size or caused any problems. So I agree with Stevo; ignore it. (but it won't go away!)
Johnny Vans
Brooklands Edition M3W
1935 F2
2021 Mini Electric
