1 members (linklaw),
125
Old Book
Goodwood
Topics49,932
Posts838,511
Posts: 8 |
I think I picked up a stone under my belt it caused a cut in thedge of the belt. I'm wondering if having a nick in an otherwise excellent belt is really all that important. In any event I would like to purchase another to have in stock.
Are the drive belts Morgan only, or can these belts be purchased elsewhere from a manufacturer??
Thank you for any guidance.
Posts: 1,626 Likes: 25
Posts: 1,626 Likes: 25 |
S&S part number 106 0353, available from a number of sources or from Morgan
Posts: 2,244 Likes: 74
Posts: 2,244 Likes: 74 |
I would think that a small nick in the belt won't be a big problem, they are very strong and some owners have had a hole punched through the belt with a stone without failure for many miles. Probably something you don't want to run with for ages though. As Roger says, they are available from a number of places but none particularly cheap, £250 -£300. Changing the belt is not a quick job either, swing arm removal required.
Posts: 366 Likes: 37
Posts: 366 Likes: 37 |
I have seen a belt ripped to half its width and still running okay.
So personally I wouldn't bother going through the hassle of changing the belt for a mere nick.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
I had replaced the original aluminum sprocket with the Super Max which has a line of small bolts down the middle of the teeth all around. Some worked out and shredded the middle of the belt teeth. That happened over 20,000 miles ago. The belt still works. According to quite a few of the bikers I've talked with the belt should last up to 100,000 miles. They are damn strong. The other belt on the motor that drives the cams should go half of that if the case has been modified to help keep it cool.
Posts: 3,740 Likes: 82
Posts: 3,740 Likes: 82 |
The other belt on the motor that drives the cams should go half of that if the case has been modified to help keep it cool. The replacement schedule for the cambelt is now every 10,000 miles and some are struggling to last that long.
Red Leader
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Cam belt gets changed every 3 years regardless of milage, I have 3 used ones as spares all in good condition. Used and serviceable is better than broken every time.
1 member likes this:
gomog |
Posts: 60 |
For what it's worth, this late in the day, my 'Brooklands' had an 8mm hole in the drive belt when I purchased it five years ago. The MOT inspector draws my attention to it every year but it hasn't increased in size or caused any problems. So I agree with Stevo; ignore it. (but it won't go away!)
Johnny Vans
Brooklands Edition M3W 1935 F2 2021 Mini Electric
