2 members (JMcL, Clipper),
289
35
Topics49,904
Posts838,082
Posts: 1,034 Likes: 121
Posts: 1,034 Likes: 121 |
Yep, I'm with Montegue with that option, nipped up you'll never shift them by hand!
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
Never underestimate the grip strength of a bored teenager.......
Posts: 5,606 Likes: 617
Posts: 5,606 Likes: 617 |
Drill bit! ... bunch of barbarians!! π .... my wonderfully minimal keyring has one key (no door handles) and a tommy bar for the various knobs ... doesn't disturb the line of the italian suits I always wear (π€£) and nothing to identify it as belonging to the Morgan outside if I leave it on a pub table while I get my round in π K ![[Linked Image]](https://www.tm-img.com/images/2024/01/20/20240120_123547.jpeg)
Posts: 1,062 Likes: 156
Posts: 1,062 Likes: 156 |
Here's how much longer the screws I used, it looks less in the image but they're actually 7mm longer, just enough to give a good bite into fresh timber. ![[Linked Image]](https://i.ibb.co/zH1t15S/20240121-130613.jpg) And for a belt and braces approach here's the epoxy I used, my hope is it's built up and strengthened the worn threads the original factory wood screws chewed into the ash door frame back in late 2011 when Monty was first built? ![[Linked Image]](https://i.ibb.co/QnRRZgj/20240121-130740.jpg) The combination of longer screws and a smear of wood specific epoxy on their threads does seem to have done the trick, but only time will tell if it's a permanent solution to the new screws backing out as the old ones kept doing  And here's how the Torx security screws look as a replacement to the original cross heads that you can see are currently still in use on the door handle escutcheon, but soon to be replaced too. ![[Linked Image]](https://i.ibb.co/2vCHGzK/20240121-130256.jpg) ![[Linked Image]](https://i.ibb.co/jZPht1r/Screenshot-20240121-130435-Gallery.jpg) ![[Linked Image]](https://i.ibb.co/hFfwcFQ/Screenshot-20240121-130358-Gallery.jpg)
I think you'd need to be an OCD concourse judge with a magnifying glass to spot the difference. ![[Linked Image]](https://i.ibb.co/K9mXcnf/20240121-130101.jpg) And in practice from a bit further back than staring right at them from a few inches away, it's impossible to see they're no longer the original cross heads.
Posts: 177 Likes: 12
Posts: 177 Likes: 12 |
Added Door Handles. ![[Linked Image]](https://tm-img.com/images/2024/01/21/IMG_20240121_145643.jpeg) I found that you can think the door is closed but infact it's not quite closed and you end up with gaps where the wind gets in. The door catch has 2 clicks and with the side screens on we were not pulling hard enough to get to the 2nd click. So today I fitted some cheap door handles from Car builder, they fold down when not in use. Just screwed into the Ash top rail of the door, I didn't think they will come loose but if they do, I'll fit some screw inserts.
Mark 2015 +4 Ferrari Le Mans Blue
Posts: 1,987 Likes: 104
Posts: 1,987 Likes: 104 |
.....here's the epoxy I used, my hope is it's built up and strengthened the worn threads the original ![[Linked Image]](https://i.ibb.co/QnRRZgj/20240121-130740.jpg) That's a good find  and available on Ebay for a remarkably reasonable price https://www.ebay.co.uk/itm/174468570500As a model maker I have tried many different adhesives over the years. Just an observation, I meticulously DON'T mix-up the caps (which is what inserting the wood screws into the nozzles effectively does), as there's a curious property of epoxy to go off in the tubes over a few weeks when even a tiny amount of hardener mixes with the resin. Really annoying when you go to use it next time.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Added Door Handles. ![[Linked Image]](https://tm-img.com/images/2024/01/21/IMG_20240121_145643.jpeg) I found that you can think the door is closed but infact it's not quite closed and you end up with gaps where the wind gets in. The door catch has 2 clicks and with the side screens on we were not pulling hard enough to get to the 2nd click. So today I fitted some cheap door handles from Car builder, they fold down when not in use. Just screwed into the Ash top rail of the door, I didn't think they will come loose but if they do, I'll fit some screw inserts. They look lovely, good find
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Added Door Handles. ![[Linked Image]](https://tm-img.com/images/2024/01/21/IMG_20240121_145643.jpeg) I found that you can think the door is closed but infact it's not quite closed and you end up with gaps where the wind gets in. The door catch has 2 clicks and with the side screens on we were not pulling hard enough to get to the 2nd click. So today I fitted some cheap door handles from Car builder, they fold down when not in use. Just screwed into the Ash top rail of the door, I didn't think they will come loose but if they do, I'll fit some screw inserts. I once had a door fly open when negotiating a roundabout. So now, before every trip, having closed the door, I try the internal lock. If the door isnβt latched properly, the little locking lever will only go half way round the quadrant, whereas if it is fully latched, it will go the whole way, giving some reassurance.
1972 750 βComDomβ sprinter 1958 Triton 650 1992 Triumph Trophy 900
