5 members (Joe Speetjens, Adam12, MogOnTheMove, Olle H, Rovert), 309 guests, and 42 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,997
RedThree
Plus 4 2019 with GDI engine and Mazda gearbox. The gearbox is more exposed because it sits in front of the crossmember. Was hit by a stone on a dirtroad. All still working fine after another 30'000 kms.
[Linked Image]mog2 by Werni Wehrli, auf Flickr
[Linked Image]mog1 by Werni Wehrli, auf Flickr
[Linked Image]Mog by Werni Wehrli, auf Flickr
Plus 4 110 Edition 2019
Rog Offline
It’s a shame we have lost Simon. I’m sure he would have easily supplied something like this to fill the a gap, if there was demand.
Roger
That’s a very smart looking plate.
Some queries :
What’s it made of and how is it attached?
The underside looks to be slightly lower than the base of the gearbox housing - thus increasing the chance of impact?
Wouldn’t the energy from said impact be transmitted to whatever fixes the plate to the housing and thus to the housing itself?
Any mileage in cutting off the portion of gearbox that protrudes below the sump?
Reason for asking is I looked closely at this while under the car not long ago, pondered the big cut but subsequently chickened out.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Rog Offline
Thanks Chris.
It’s made from a 300 series stainless, although aluminum would have been fine.
It’s attached with a single M8 socket cap. It’s probably over the top but there is a small protruding ‘heel’ step on the back mounting face, in an attempt to bias the thin front portion of the deflector hard up to the sump casting when the bolt is tightened.
The deflector is exactly the same thickness as the gearbox step at the center, so the midpoint ground clearance has not been reduced.
Hopefully owing to the deflector’s angle, some of the impact energy will now get transferred to lifting the car/engine. However the bottom line is, the deflector is attached to a reasonably strong part of the gearbox casting and is sat on the very stiff vertical edge of the sump casting. I’m happier now with it in place, compared to how the car left the factory.
Like you, I pondered long and hard about cutting that protruding portion off but decided it was a bad idea in the end. It could create a gaping hole through to the clutch assembly. Then I would have needed to make/fix a cover plate to keep the muck and wet out. It was much easier to attach the deflector. Once the deflector was on it also crossed my mind to lop off that little protruding lug on one side that you can see. But again, why butcher the casing unnecessarily. Should the lug ever be impacted, it will probably just snap clean off anyway. So no real harm done…
Roger
So does this deflector actually exist, or is it just an idea? If it does exist where can I source one?
I think it's good as it protects the gearbox housing which is more susceptable to damage that the cross member.
Roadster 3.7
Plus 4 110 Anniversary
Plus 4 Fiat TC
It can be mis-leading to purely look at what is the lower… gearbox or chassis.crossmember. I have had many hits on the crossmember but rarely on the gearbox. This must be because the gearbox is nearer the front wheels, so gets a better elevation when traversing sleeping policemen, whereas once the wheels are over, the crossmember then becomes the prime target, with no help from front wheels. Traversing at an angle sometimes helps but not always successful.
I have been tempted with bash plates but of course it reduces the ground clearance even more. When my tyres come up for renewal next year I am going for 65 profile all round instead of the standard 60. I am pretty sure it won’t noticeably affect gearing, and speedo is easy to adjust if needs be.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
sewin Offline OP
I went with the 65 profile on my plus 4 last year from the 60 as fitted by MMC. Primarily to add to ride comfort but also to take advantage of the slight increase in ride height and therefore ground clearance of an extra 10mm. I checked the speedometer against a sat nav device, road angel, and its reading was spot on! Hadn't checked prior to the change though, although I suspect it probably over read like most cars do.
For me the change has been greatly welcomed as the ride quality is improved no end and I wouldn't say the handling has altered detrimentally, certainly not for the road anyway. If it were a track car I would stay with the 60's as they are more urgent but I really am enjoying the car much more for general driving. Only disadvantage is changing all 5, however they are standard VW Polo tyre's so readily available and cheap for top branded options.
Feedback much appreciated. Although I changed all 4 road tyres in late 2016, my spare is OEM and so now 12 years old but never used, so not a bad idea to change it anyway.
Doug
1958 Triton 650
Rog Offline
Don’t hesitate Doug. 65 profiles tyres was about the first change that I did after getting the +4. As Sewin say, the speedo is spot on.
Roger
Doug
1958 Triton 650
