8 members (Sir Percival, SteveT, Chris99, uvk33n, MJF, sid, Saxonian, Soleng), 238 guests, and 35 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,131
Page 91 of 165 1 2 89 90 91 92 93 164 165
I put the new bumper tube assemblies on the 4/4 this morning. I'll probably be spending the next few days trying to figure out how to adjust them so they look, well, balanced.
1958 4/4 Series II Roadster
Rog Offline
Today’s little wet day job was a bit of future disaster prevention. Out with that dodgy nylon coolant T piece and in with a stainless version. It’s been on my list for long while.
Roger
Nice. I got an ali version from SiFab
Yes, this bothered me as well. Here the replacement with lenghts in metric measures. Plus 4 2019
[Linked Image]IMG_4462 by Werni Wehrli, auf Flickr
Plus 4 110 Edition 2019
The non-plastic tee piece is a worthwhile modification. I raised the whole assembly off the aluminium box with a plastic and rubber block retained by a cable tie to prevent annoying rattles.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
1 member likes this: RichardV6
Adjusted camber using my magnetic gauge - once I'd found it innocent
Nearside found to have 1° of negative camber, now corrected.
Where was it? .... I'm looking for mine and they may have some ancestral instinct to hide in certain places!! 😁
In the garage but on one of many shelves in a box with gardening knick knacks confused2
You can attach to your spade so you get the perfect angle of attack for weeds laugh2
Rog Offline
Not so sure that I’m happy with this new stainless T today. Should have got a Sifab ali one… ooo
Out of curiosity today I measured the voltage between the T and the ali rad cooling fins. It was showing around 1v, which is about 3 times more than the other stainless pipework in the cooling system is generating (there are many grades of stainless with a range of different noble potentials). Now I’m suspecting that introducing this grade of stainless is not an ideal mix for the longevity of my super expensive ali rad from a galvanic perspective. I could well be wrong... but have ordered up an aluminum T anyway.
Roger
