Posts837,997
Posts: 43 |
I put the new bumper tube assemblies on the 4/4 this morning. I'll probably be spending the next few days trying to figure out how to adjust them so they look, well, balanced.
1958 4/4 Series II Roadster
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Today’s little wet day job was a bit of future disaster prevention. Out with that dodgy nylon coolant T piece and in with a stainless version. It’s been on my list for long while. ![[Linked Image]](https://tm-img.com/images/2024/02/13/T-piece.jpeg)
Roger 2011 Plus 4
Posts: 27,836 Likes: 761
Posts: 27,836 Likes: 761 |
Nice. I got an ali version from SiFab
Posts: 104 Likes: 18
Posts: 104 Likes: 18 |
Yes, this bothered me as well. Here the replacement with lenghts in metric measures. Plus 4 2019 IMG_4462 by Werni Wehrli, auf Flickr
Plus 4 110 Edition 2019
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
The non-plastic tee piece is a worthwhile modification. I raised the whole assembly off the aluminium box with a plastic and rubber block retained by a cable tie to prevent annoying rattles. ![[Linked Image]](https://tm-img.com/images/2024/02/14/IMG_5226.png)
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
1 member likes this:
RichardV6 |
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
Adjusted camber using my magnetic gauge - once I'd found it  Nearside found to have 1° of negative camber, now corrected.
Posts: 5,594 Likes: 612
Posts: 5,594 Likes: 612 |
Where was it? .... I'm looking for mine and they may have some ancestral instinct to hide in certain places!! 😁
In the garage but on one of many shelves in a box with gardening knick knacks
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
In the garage but on one of many shelves in a box with gardening knick knacks  You can attach to your spade so you get the perfect angle of attack for weeds
Nice. I got an ali version from SiFab Not so sure that I’m happy with this new stainless T today. Should have got a Sifab ali one…  Out of curiosity today I measured the voltage between the T and the ali rad cooling fins. It was showing around 1v, which is about 3 times more than the other stainless pipework in the cooling system is generating (there are many grades of stainless with a range of different noble potentials). Now I’m suspecting that introducing this grade of stainless is not an ideal mix for the longevity of my super expensive ali rad from a galvanic perspective. I could well be wrong... but have ordered up an aluminum T anyway. ![[Linked Image]](https://tm-img.com/images/2024/02/14/T-volts.jpeg)
Roger 2011 Plus 4
