3 members (Graham, G4FUJ, dakri, Montegue), 131 guests, and 51 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Page 96 of 164 1 2 94 95 96 97 98 163 164
Originally Posted by Rog
Snug describes it well Keith and it sealed on the first attempt just by nipping up with a screwdriver.
On that basis, think I will go for 16mm which is bound to fit rather than trying to tightly squeeze a 19mm in, which may put a strain on the internal reinforcing of the pipe.. 🤞
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Black Rat
Black Rat
Thanks Rog I'll give it a try in the week, I can't make out wether my plastic one says 16 or 18 on it.
Keith
2013 narrow bodied + 4 Ruby.
It will be 16mm (â…ť") Keith. That's the default size for most heater hose i/d.
Here are pictures of the T I took off my S1 Roadster. Pipe OD at inlet 16mm and 17mm at the widest.
While waiting for my engine to get back I pulled the wheels to check the brakes. 3 of the 4 looked perfect, the right rear had grease around the seal and on the springs. I pulled the hub off to gain access. It may have been that the weep hole was a bit plugged last time I added grease and some pressed it's way through the seal. Cleaning it up and checking the hole may have been all that was needed, but since I have the time I might bas we'll replace the seal.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Originally Posted by Deejay
I notice his plastic one is marked TS 16, but agree it does look a little bigger.
Yes its bigger, on the end…. smile
Changed my tee piece over today with a 16 mm aluminium one from Viper.
Bit of a wrestle to get the plastic one off! The new one slid in with no resistance at all. Would have felt better if it had been a tad bigger, though next size up at 19 mm might be pushing it a bit.
Anyway, tightened down, ran up to stat opening temperature and no leaks, all pipes hot and heater working fine.
Still got half a cup full of coolant left over but guess air will percolate out on my next run and I can then top up.
Doug
1958 Triton 650
Doug,
I remember I had to cut one of the hoses it wouldn't pull off on one of the legs. Well done
Rog Offline
Well done Doug.
A bit late but a quick squirt of silicone lube down the back of the pipe will help the old one let go.
Roger
Well done Doug.
A bit late but quick squirt of silicone lube down the back of the pipe will help the old one let go.
Thanks Rog. I got it turning ok but think it was the big end barb that didn't want to go through the section that had been clamped.
Once I chose the right swear words, it popped off!
The new one of course has barbs all of the same diameter, which although would make it easier to push onto a tight tube but maybe a little less effective when the jubilee clip is applied. Assume you have now fitted the fleabay aluminium one?
Doug
1958 Triton 650
Rog Offline
Not yet Doug, mine is on a slow boat from china waiting
Roger
