10 members (JohnHarris, jbk, Mogdavid, Oliemog, Neville1, Julian BB, DalesPlusFour, TalkMorgan, Hamwich, Graham, G4FUJ),
346
37
Topics49,915
Posts838,208
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
Snug describes it well Keith and it sealed on the first attempt just by nipping up with a screwdriver. On that basis, think I will go for 16mm which is bound to fit rather than trying to tightly squeeze a 19mm in, which may put a strain on the internal reinforcing of the pipe.. 🤞
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Snug describes it well Keith and it sealed on the first attempt just by nipping up with a screwdriver. Thanks Rog I'll give it a try in the week, I can't make out wether my plastic one says 16 or 18 on it.
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
It will be 16mm (⅝") Keith. That's the default size for most heater hose i/d.
Posts: 27,852 Likes: 767
Posts: 27,852 Likes: 767 |
Posts: 810 Likes: 59
Posts: 810 Likes: 59 |
While waiting for my engine to get back I pulled the wheels to check the brakes. 3 of the 4 looked perfect, the right rear had grease around the seal and on the springs. I pulled the hub off to gain access. It may have been that the weep hole was a bit plugged last time I added grease and some pressed it's way through the seal. Cleaning it up and checking the hole may have been all that was needed, but since I have the time I might bas we'll replace the seal. ![[Linked Image]](https://www.tm-img.com/images/2024/02/18/1000002220.jpeg)
I notice his plastic one is marked TS 16, but agree it does look a little bigger. Yes its bigger, on the end…. ![[Linked Image]](https://tm-img.com/images/2024/02/17/t16.jpeg) Changed my tee piece over today with a 16 mm aluminium one from Viper. Bit of a wrestle to get the plastic one off! The new one slid in with no resistance at all. Would have felt better if it had been a tad bigger, though next size up at 19 mm might be pushing it a bit. Anyway, tightened down, ran up to stat opening temperature and no leaks, all pipes hot and heater working fine. Still got half a cup full of coolant left over but guess air will percolate out on my next run and I can then top up.
Doug, I remember I had to cut one of the hoses it wouldn't pull off on one of the legs. Well done
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Well done Doug.
A bit late but a quick squirt of silicone lube down the back of the pipe will help the old one let go.
Roger 2011 Plus 4
Well done Doug.
A bit late but quick squirt of silicone lube down the back of the pipe will help the old one let go. Thanks Rog. I got it turning ok but think it was the big end barb that didn't want to go through the section that had been clamped. Once I chose the right swear words, it popped off! The new one of course has barbs all of the same diameter, which although would make it easier to push onto a tight tube but maybe a little less effective when the jubilee clip is applied. Assume you have now fitted the fleabay aluminium one?
Not yet Doug, mine is on a slow boat from china
Roger 2011 Plus 4
