8 members (Anonymouse, Chris Cosher, Alan Patterson, bmgermany, Luddite, Julian BB, Vansrv6, JohnHarris),
272
Topics49,899
Posts838,033
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
When I swapped the dash on Belle I didn't swap the switches. The heated screen didn't work. It turned out the switch was faulty & my old one worked fine. The printed circuit board is as you say vulnerable & I suspected a dry solder joint.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
A friend has a Plus4, when he took it for its first MOT neither the rear fog lights or reversing light were even connected! They all do that Sir!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
I had similar on my Plus8 rear foglight. Started as intermittent flashing on/off, even when not switched on. Checked fuse and ok. Worked back from the bulb and nothing obvious. Dash off and checked the switch and control box. Switch ok but the box rattled so opened it. The pcb inside was loose so hotmelt glued it back. Worked for a while then played up. Opened the box and all appeared ok. Tried getting a replacement but none available ( tried Melvyn Rutter and even factory direct) none available. Plenty in the factory for older Plus8’s but not the later models. GRRRR! I was about to order a unit from Carbuildersolutions when under a magnifier I spotted a couple of iffy solder joints. Quick dab with a soldering iron and fixed. No subsequent problems. The car was about 13/14 years old. Electrics getting old ( relatively). Hence starting to think about long term ownership plans/system overhauls.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Have you checked that you have a good clean earth connection to the light?
Posts: 7 Likes: 1
Posts: 7 Likes: 1 |
Yes I did that. Disappointment ensued when it when I found it was fine.
Posts: 7 Likes: 1
Posts: 7 Likes: 1 |
Hi Rog, sorry about the delay Ive been working  so I havent had time to play. I've got the dash out and I will make sure i can get some light straight onto the multipin connector tonight. Once I've done that I will put some life into the board and see what comes out.. I'll let you know
Posts: 7 Likes: 1
Posts: 7 Likes: 1 |
Guys, Thanks for the help. Relay was goosed. RS/Farnell/CPC don't have them ( Think they are out of production) but found some at Pennine components £1.35 a piece. PIC is locked but I cant say I'm surprised by that.
Sales 01706 815737 Email:sales@penninecomponents.co.uk
1 member likes this:
RichardV6 |
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Roger 2011 Plus 4
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
Has anyone installed These on a car with the rear valance? Seems a great idea, but two things come to mind. 1) any problem with that dash circuit board. ie over loading the components on it. 2) Sourcing another clear lens “cover”
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
Not used the kit, but have done the same using stop/taill lights and clear lens - Lucas L594 - from eBay and bulbs from Classic Car Leds, Just over £50 all in. As the bulbs are LED I doubt there'll be problems as the draw from both would be less that a single halogen. However, my knowledge of modern electrickery is limited. https://www.classiccarleds.co.uk/pr...mp;_psq=reverse+fog&_ss=e&_v=1.0![[Linked Image]](https://www.tm-img.com/images/2022/03/18/Rear.md.jpg)
