7 members (RedThree, Davetherave, Grumpy2, Craig Jezz, Aeromax51, Socalm3w, Gambalunga), 256 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,145
Page 3 of 4 1 2 3 4
Mark+4 #796645 28/02/24 08:15 AM
That’s more like it!
Only comment is that if it’s going to be mounted behind the dash, it might be wiser to go for the fully enclosed version to protect against the infamous Morgan water leaks, which is what has wrecked many of the original pcb installations.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Mark+4 #796717 29/02/24 09:15 AM
In the end I went with this one for £11.00 from a UK seller:
* Internal forward & reverse relays so the original Lorlin 1a rotary fan switch can be used
* Easy to wire in the original fan switch
* Remote pot
* Rated 40a (30a continuous)
* Vented enclosure
Obviously I just need the forward circuit, but the forward and reverse versions use relays which I prefer given I want to use the original Lorlin 1a rotary fan switch.
Search eBay item number: 204515866552
Rog #796725 29/02/24 10:39 AM
Mark+4 Offline OP
Quote
Yes I think that you will need a new 4 way switch. I believe the switch at the moment is a fixed 3 way, with 4 poles (so 12 positions total). It only uses 1 pole so will have 3 poles free but I don’t think that will help you. The stop can be adjusted to limit the rotation.
Hi Rog,
Is the stop something that can be adjusted by me, or is it set when the switch is manufactured? and hence why I need a new switch.
Have been looking at new switches and it also looks like I need to know if the current switch is "Make" or "Break" before make, does anyone know which it is.
Thanks
Mark
2015 +4 Ferrari Le Mans Blue
Mark+4 #796729 29/02/24 11:26 AM
Rog Offline
Originally Posted by Mark+4
Hi Rog,
Thanks
Yes you can adjust the stop. It’s the little tab here that you poke in the appropriate hole.
My switch looks to be a Lorin and here's the data sheet. There are lots of other options here.
I’m sure the electrical wizards will confirm, but perhaps if you used a 3 pole 4 way, you could use all the pole contacts and maybe have triple the 1A @ 24V per contact current rating? Depending on your new fan load, you might save yourself a relay?
For reference, here’s the back of mine.
Roger
Mark+4 #796731 29/02/24 12:01 PM
Mark+4 Offline OP
Thanks Rog,
That looks really simple to do.
So forgive the next stupid question.
Could I connect 2x Poles together to make a bank of 6 position that would share an earth and then limit to the 4 positions I need? or is there some electrical rule that says this is not a good idea?
Mark
Mark+4 #796735 29/02/24 12:54 PM
So it's appears to be a wafer switch allowing up to 4 poles and up to 12 way but not both. Also an adjustable mechanical stop.
The data sheet suggests different wafers are needed to achieve the various combo's. As Morgan OE it appears to be set up for single pole 12 way (make before break) with the mechanical stop set at just three 30° position increments. Does this sound correct Rog?
If so then Mark would need a different wafer or most likely order a different switch combo from your eBay link, as 2 pole 6 way is an option.
It does appear that having the four pole, three way wafer the poles and corresponding contacts could be paralleled up to give 4 amp rating...... maybe thinking
Rog Offline
If I understand the question correctly, it can't be changed. There are 12 positions with 4 poles, each pole having 3 ways or contacts. The number of ways is fixed by the switches wiper geometry. However, the number of positions can be reduced using adjustable stop
I think Mark needs 4 ways/positions so maybe only 3A?
I hope that I have my poles and ways the right way around stars
Roger
Mark+4 #796739 29/02/24 02:29 PM
Thanks that's exactly how I understood it Rog thumbs
So in answer to Mark you can order a new similar two pole six way switch via Rog's eBay link and put the mechanical stop at fourth position. You would need to parallel up both the poles and the respective four way contacts though to take advantage of the increased current rating.
Mark+4 #796743 29/02/24 03:18 PM
Here is the knob on my 2014 Roadster showing the connections. It is bottom left of the 3 controls. Also note the bowden cable connector & quadrant
Montegue #796757 29/02/24 05:05 PM
Rog Offline
* Remote pot
* Vented enclosure
Dave, is that a bi directional pot? If you swapped it for a regular single direction long shaft pot, with a switch incorporated, it might all fit neatly in place of the Lorin switch. Then you would have full control using the standard knob.
Roger
Page 3 of 4 1 2 3 4
