5 members (John Winn, Carbuilder, Davetherave, RichardV6, IcePack), 264 guests, and 31 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,043
BigLes #800429 16/05/24 09:21 AM
My single wipe function has given up. Push the lever down & let go. Wipers start to wipe but stop when lever released at the position they are in at the time of release. However if lever is pushed all the way down a rapid wipe works & on release the wipers park correctly.
What do I look at 1st. Stalk, relay or contacts in wiper box. (I assume you can get at them) 2011 4/4. All other functions working correctly.
BigLes #800430 16/05/24 09:23 AM
Black Rat
Black Rat
Mine start and carry on and on and on
Keith
2013 narrow bodied + 4 Ruby.
BigLes #800439 16/05/24 10:40 AM
Its the switch on the wiper motor itself, dead easy change. Switch is used on everything that had this GM type motor drive so, mini original Morris miner etc. Land rover Defender used it right up until they stopped making them 2015/16. you'll pay anything from £8-£20 they are really all made in china now but when you remove yours you will see its got a few letters on it, can't remember what but these are the better quality so try for that option. Also try and get the ones with the neoprene gasket inside the terminal block as this prevents moisture entering and corroding the terminals. Don't bother trying to fix the one you have its the breaker contact inside that will be corroded and not making the right connection.
If you want one quickly go into a Land Rover dealer and they'll have them on the shelf but it'll cost about £21.00+vat and it's exactly the same thing from the same place!
Under five minute job when you have the switch!
BigLes #800450 16/05/24 01:25 PM
Sewin thank you for that. I’ll source one, probably from EBay.
BigLes #800459 16/05/24 03:14 PM
Black Rat
Black Rat
I pulled the wiring connector off the motor , the pins were rusty so i squirted some switch cleaner on them and it seems to work now.
Keith
BigLes #800604 19/05/24 05:28 AM
Online NoMood
This should work if needed.
BigLes #800616 19/05/24 05:44 PM
Richard Thanks, that is the one I have on order.
Hopefully solve the fault.
BigLes #801203 30/05/24 06:37 PM
Fitted & everything works. Old one was a bit of pain removing. New one went on fairly easily, Had to loosen the motor gearbox to gain access.
