3 members (RalfL, Alan Patterson, JohnHarris), 254 guests, and 42 robots.
+8Rich 103
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,917
Posts838,230
MossyfromNZ
Page 103 of 165 1 2 101 102 103 104 105 164 165
Changed brake fluid with the help of swmbo on the pedals.
Fun for the neighbours listening on the other side of the garden fence…”in, out, in, out, in…hold it in!” 🤪
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
laugh2 laugh2 laugh2
Gave the battery cover a spray in Morgan sports blue. Nobody will notice it, but I know it is there.
[Linked Image]20240417_161541 by Werni Wehrli, auf Flickr
Plus 4 110 Edition 2019
Love it.
Just the sort of thing I would do.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
Is your ctek lead fused?
Mine is to be safe.
I painted the wood black with Sandolin preservative shortly after getting car. Masks the grubby fingerprints that appear as well.
Mine is to be safe.
Good point. Thank you.
CTEK lead is indeed not fused. They don't mention this possibility, which I think is a flaw. Will add it. Only wrapped around additional tape to prevent chafing on the hole in the wall. Leads are screwed with eyelets directly to battery the poles.
They do make a unit with an inline 15 A fuse. Such as this eBay item number:273836223613
Also what the screws that hold onto the plate I had a bad experience when a garage replaced a screw with a longer one that cut into the +ve cable. The plate is then live.
Mine is to be safe.
My Maypole charger provides for a similar permanent battery connection (with insulated cap) as well as crocodile clips. There is a fuse which I suspect the Ctek has as well but it's on the charger side of common lead. It's all a little academic when you consider the dedicated starter cable following common practice, has no fuse at all between battery and starter motor.
Maybe Richard but the CTEK cable is far smaller & exposed to the items behind the seats. I know the wire would act as a fuse too but having watched my previous Roadster starting to catch fire I prefer a fuse.
