7 members (John Winn, TalkMorgan, GrumpyPa, Rog G, RichardV6, Laurens, Craig Jezz),
341
38
Topics49,918
Posts838,244
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
Changed brake fluid with the help of  on the pedals. Fun for the neighbours listening on the other side of the garden fence…”in, out, in, out, in…hold it in!” 🤪
1 member likes this:
CooperMan |
Posts: 8,706 Likes: 416
Posts: 8,706 Likes: 416 |
Posts: 104 Likes: 18
Posts: 104 Likes: 18 |
Gave the battery cover a spray in Morgan sports blue. Nobody will notice it, but I know it is there. 20240417_161541 by Werni Wehrli, auf Flickr
Plus 4 110 Edition 2019
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Gave the battery cover a spray in Morgan sports blue. Nobody will notice it, but I know it is there. 20240417_161541 by Werni Wehrli, auf Flickr Love it. Just the sort of thing I would do. Bud 4/4 - Stanley
Bud 4/4 "Stanley"
Posts: 27,853 Likes: 767
Posts: 27,853 Likes: 767 |
Is your ctek lead fused? Mine is to be safe.
I painted the wood black with Sandolin preservative shortly after getting car. Masks the grubby fingerprints that appear as well.
Is your ctek lead fused? Mine is to be safe. Good point. Thank you. CTEK lead is indeed not fused. They don't mention this possibility, which I think is a flaw. Will add it. Only wrapped around additional tape to prevent chafing on the hole in the wall. Leads are screwed with eyelets directly to battery the poles.
They do make a unit with an inline 15 A fuse. Such as this eBay item number:273836223613 Also what the screws that hold onto the plate I had a bad experience when a garage replaced a screw with a longer one that cut into the +ve cable. The plate is then live.
Is your ctek lead fused? Mine is to be safe. Good point. Thank you. CTEK lead is indeed not fused. They don't mention this possibility, which I think is a flaw. Will add it. Only wrapped around additional tape to prevent chafing on the hole in the wall. Leads are screwed with eyelets directly to battery the poles. My Maypole charger provides for a similar permanent battery connection (with insulated cap) as well as crocodile clips. There is a fuse which I suspect the Ctek has as well but it's on the charger side of common lead. It's all a little academic when you consider the dedicated starter cable following common practice, has no fuse at all between battery and starter motor.
Maybe Richard but the CTEK cable is far smaller & exposed to the items behind the seats. I know the wire would act as a fuse too but having watched my previous Roadster starting to catch fire I prefer a fuse.
