Topics49,883
Posts837,819
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Does the gearbox drain plug have a washer on 2005 Plus 4? Thanks.
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
I would have thought a copper washer would be used .
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
My 2011 4/4, does not. (I was surprised it didn't)
Is it Mazda gearbox ? Says on the owners site a copper washer is used
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Copper washer or a Dowty washer and a couple of turns of PTFE tape around the threads on the drain plug
Arwyn
Posts: 1,021 Likes: 120
Posts: 1,021 Likes: 120 |
My 2010 plus 4 with the MT-75 gearbox has alloy crush washers, they tend to stick to the gearbox and look as though they are the gearbox surface but you can flick them off easily enough! They don't use copper as it could erode the face surface of the gearbox causing a leak down the line (reactivity series of metals scale). I have reused my alloy crush washers several times with no problems.
Posts: 185 Likes: 2
I drained the gearbox (MT75) today and it had alloy washers with a rubber type inner edge. Luckily I had exactly the ones needed so all was good.
Posts: 8,685 Likes: 414
Posts: 8,685 Likes: 414 |
That's sounds like a Dowty washer although the metal is usually steel. Work well on high pressure hydraulic fittings but not so well as a seal that isn't under pressure I have found.
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Slight thread drift……my sump has a dowty washer, an original fitting. Being alloy I’ve never been sure the correct torque but go less than usual for a sump, to18 lb/ft. Ditto for gear box. But, if anyone has alternative advice I’d appreciate it. ![[Linked Image]](https://tm-img.com/images/2019/12/11/image1.th.jpg)
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 185 Likes: 2
[quote=SALMO]Slight thread drift……my sump has a dowty washer, an original fitting. Being alloy I’ve never been sure the correct torque but go less than usual for a sump, to18 lb/ft. Ditto for gear box. But, if anyone has alternative advice I’d appreciate it.
I did mine to 25lb/ft
