7 members (Plus Four Guy, IcePack, TBM, tezzer, jbk, DazMog, Chris Cosher), 220 guests, and 49 robots.
+8Rich 70
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,883
Posts837,822
Gyp
#800383 14/05/24 07:19 PM
Does the gearbox drain plug have a washer on 2005 Plus 4? Thanks.
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
I would have thought a copper washer would be used .
My 2011 4/4, does not. (I was surprised it didn't)
Is it Mazda gearbox ? Says on the owners site a copper washer is used
Copper washer or a Dowty washer and a couple of turns of PTFE tape around the threads on the drain plug
Arwyn
My 2010 plus 4 with the MT-75 gearbox has alloy crush washers, they tend to stick to the gearbox and look as though they are the gearbox surface but you can flick them off easily enough! They don't use copper as it could erode the face surface of the gearbox causing a leak down the line (reactivity series of metals scale). I have reused my alloy crush washers several times with no problems.
I drained the gearbox (MT75) today and it had alloy washers with a rubber type inner edge. Luckily I had exactly the ones needed so all was good.
2005 Plus 4
2020 Hyundai eKona
That's sounds like a Dowty washer although the metal is usually steel. Work well on high pressure hydraulic fittings but not so well as a seal that isn't under pressure I have found.
Slight thread drift……my sump has a dowty washer, an original fitting.
Being alloy I’ve never been sure the correct torque but go less than usual for a sump, to18 lb/ft. Ditto for gear box.
But, if anyone has alternative advice I’d appreciate it.
[Linked Image] [Linked Image]
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
[quote=SALMO]Slight thread drift……my sump has a dowty washer, an original fitting.
I did mine to 25lb/ft
2005 Plus 4
2020 Hyundai eKona
