1 members (Detlev V6),
141
32
Posts838,003
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
1845sailor ... what a cracking car .... lots of good stuff on it .... must be great to drive!
K It is a true joy to drive this car. I cannot wait to get her back on the road...
I had the grille out to make some adjustments to the valance and I painted the top plate black. I like it much better,,, ![[Linked Image]](https://www.tm-img.com/images/2024/06/01/IMG_6013-copy.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2024/06/01/IMG_6774.md.jpg)
Posts: 2,119 Likes: 70
Posts: 2,119 Likes: 70 |
I had the grille out to make some adjustments to the valance and I painted the top plate black. I like it much better,,, ![[Linked Image]](https://www.tm-img.com/images/2024/06/01/IMG_6013-copy.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2024/06/01/IMG_6774.md.jpg) Looks very nice! Perhaps I should do the same? But when......
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
I've been having problems with the handbrake not locking on, so decided to investigate. I removed the handbrake and found the pawl looked a bit worn. A light regrind of the flat which engages with the quadrant seems to have solved the problem. It was just a long winded process removing the seats and the tunnels to get to the handbrake lever but it did give me the opportunity to grease the UJs and the clutch mechanism.
1956 Plus 4 4 seater
Posts: 132 |
I had the same problem, and executed the same fix. It sadly didn't last.
I'd strongly recommend anyone else attempting this repair, that they buy a new rack. They are not expensive. If you have removed parts to get here, repairing both the rack and pawl is the way to go.
I'd strongly recommend anyone else attempting this repair, that they buy a new rack. They are not expensive. If you have removed parts to get here, repairing both the rack and pawl is the way to go. I replaced the quadrant rack last year, but the pawl had been incorrectly made so I had to use the original one. I noticed that the pawl can rotate slightly which can prevent it locking properly. A slight twist of the button straightens the pawl and then it locks. I guess a slightly longer locking screw which locates the pawl may help, just didn't have one handy.
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
I had the same issue when I tried to replace the pawl. It wouldn't fit in the hole. Used the old one with the new teeth and all was good.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
I made a new pawl, took me 20 mins.
Arwyn
Arwyn It's been many years since I had the facilities to do that At least you get it right, which MMC who supplied Mervyn couldn't do. The one Mervyn supplied had the flat in the wrong place.
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Drove out to a country pub at Saxted in the Suffolk countryside for lunch with Richard (RichardV6) and Gary (Hawki), so the conversation probably strayed onto bikes at some stage, then home for an oil and filter change. ![[Linked Image]](https://www.tm-img.com/images/2024/06/05/IMG_4088.md.jpeg)
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
