0 members (), 292 guests, and 18 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
Page 108 of 164 1 2 106 107 108 109 110 163 164
Black Rat
Black Rat
Drove up to Cambridge to Cain at Wolf Performance for a service and suspension upgrade, my AVO's were shot. Service went well all the brake pads were removed to de-glaze, rear drums removed and cylinders checked. I had bought online a coil cover which was supposed to fit but didn't, needed some work to make it fit, now fitted. The shot AVO's were replaced with new Wolf shockers, these are about half the weight Aluminium cases. Transformed the ride, no bottoming out any more, smoothed the road out. Ride home was nightmare on the M11 static and very slow from J9 right through to J8 1 1/2 hours HGV with split tank lane 1 covered in diesel and only HATO's on scene with not a clue how to deal.
Keith
2013 narrow bodied + 4 Ruby.
Hi, Sailor,
Which light guards did you use when you fitted them?
.[Linked Image]
Fitted the rubbing strips from woolies cost £4. thanks for all the replies.
The originals had been in place for 40years I think they deteriorated because I started to oil them, ( rubber does not like oil) lesson learned.
David Byrne
It depends on the rubber. Synthetic rubbers can be oil resistant. They all though don't like UV & ozone. 40 years is a pretty good shelf life.
What is a coil cover?
Surprised how your 2013 car seems to eat shockers. Don’t think AVOs were OEM, so it must now be on its third set… High mileage, live up a farm track, or maybe the wrong spec. AVOs were fitted last time?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Originally Posted by sewin
Hi, Sailor,
They were on the car when I got it, So I don't know the source. Sorry.
Black Rat
Black Rat
Doug a coil cover goes on top of the engine and covers the spark plugs perhaps better described as engine cover originally designed for Caterhams with Duratec engines. You are correct AVO'S are not OEM, fitted about 20k ago yes it's now on its third set at 47k.I live in Essex so roads not good and it does get driven. King pins only lasted 5 years, hard chrome now fitted.
Keith
That A12 is a car killer.
Hi, Sailor,
Something like this ?
https://www.minisport.com/monhg1-headlamp-guards-7-inch-stainless-steel-pair-classic-mini.html
Thanks. All understood now.
I’m still running OEM at 51k miles.
Doug
1958 Triton 650
