New
Topics48,365
Posts813,389
Members9,215
Posts: 121 |
Hi everyone. Does anyone know the original manufacturer of the steering column and hence steering lock, please. Embarrassingly in France recently I delayed the groups progress for 20 minutes whilst I tried to get the steering lock free, and need a replacement. I imagine it might be BL ??? Kind regards, John.
Posts: 7,944 Likes: 218
Posts: 7,944 Likes: 218 |
If it looks at all like this John it's a Valeo item used on Rover 800 series. ![[Linked Image]](https://i.ebayimg.com/images/g/pL8AAOSwddpmF-q~/s-l1200.jpg) See here for source. After chiselling off bolts you manage to repair old one, fresh break off bolts are available on eBay.
Posts: 121 |
Thank you Richard. The key certainly looks identical, I'll take the plastic cover off later and look at the lock. Cheers, John.
Posts: 28,429 Likes: 180
Posts: 28,429 Likes: 180 |
I never bothered with the snap off bolts when I had to replace the steering lock on an older car.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 1,961 Likes: 43
Posts: 1,961 Likes: 43 |
Seem to recall that John v6 had a problem some time ago with his roadster lock jamming. Once removed he gave it a good soaking with chain oil and applied a pliers to turn the key and it worked perfectly. (bit of a sh*t or bust method, but could save a few bob?)
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
I certainly did & I bought a spare off fleabay. After apply motorbike chain grease via an aerosol I let it soak in then turned it upside down. The crud that came out was amazing. I replaced the bolts with normal ones to facilitate any issue from further failure.
Posts: 121 |
Thank you again Richard, I bought the one on ebay in your link, just have the little issue of fitting it. Cheers, John.
