9 members (DCH, flyfisher, B3MOG, Chris Cosher, DJC, TBM, auster, John V6, sprinty), 245 guests, and 30 robots.
+8Rich 102
John V6 60
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,185
Georgetoad, woolfie
Page 68 of 173 1 2 66 67 68 69 70 172 173
P.S.
screwfix sell a large spray can of penetrating oil for little money!
If it doesnt regularly bottom out it is fine. Drive it & grin
Originally Posted by sewin
P.S.
But if it's cheap nasty stuff it may attack the rubber shackle bushes
I always buy from a motorbike shop and check it says O Ring safe, (chain lube)
We were out in the Roadster to catch the late sun last evening. For a while I have wondered if I have "Roadster spring sag", what do you reckon ? And if the answer is yes, should I just spend the money on an SSL 5-leaf rear conversion ? (I have the SSL front).
Peter, if when you fitted the front end SSL you set up the spacers to give better sump clearance on the Roadster...as this raises the front arch to wheel gap, it will emphasise the lower gap at the rear even if you don't have 'saggage'
Thanks, good point. The SSL front (which was done for me) certainly improved the ride and handling at the front end, but I have since been of the opinion that the rear isn't singing from the same songsheet. At next service/MoT time, I will be using a different specialist to do a general revamp of the suspension. It will be money spent that I wlll never see back, but will make me more likely to hang onto the car.
P.S.
Me too
Today I went to Central Morgan in Nottingham & back c 300 miles. I bought a red 2022 Plus Four so sadly now I have to part with my trad.
Welcome"John-streight4". 🥳
Enjoy you new car!
1 member likes this: John V6
OMG ! Well, I didn't see that one coming John, enjoy !
Neither did I but fate intervened.
