Topics48,362
Posts813,329
Members9,215
Posts: 688 Likes: 62
Posts: 688 Likes: 62 |
P.S.
screwfix sell a large spray can of penetrating oil for little money!
Posts: 26,759 Likes: 424
Posts: 26,759 Likes: 424 |
If it doesnt regularly bottom out it is fine. Drive it & grin
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
P.S.
screwfix sell a large spray can of penetrating oil for little money! But if it's cheap nasty stuff it may attack the rubber shackle bushes I always buy from a motorbike shop and check it says O Ring safe, (chain lube)
We were out in the Roadster to catch the late sun last evening. For a while I have wondered if I have "Roadster spring sag", what do you reckon ? And if the answer is yes, should I just spend the money on an SSL 5-leaf rear conversion ? (I have the SSL front). ![[Linked Image]](https://www.tm-img.com/images/2024/06/27/26-6-24-Wilverley-1.jpg) Peter, if when you fitted the front end SSL you set up the spacers to give better sump clearance on the Roadster...as this raises the front arch to wheel gap, it will emphasise the lower gap at the rear even if you don't have 'saggage'
Posts: 1,784 Likes: 53
Posts: 1,784 Likes: 53 |
Thanks, good point. The SSL front (which was done for me) certainly improved the ride and handling at the front end, but I have since been of the opinion that the rear isn't singing from the same songsheet. At next service/MoT time, I will be using a different specialist to do a general revamp of the suspension. It will be money spent that I wlll never see back, but will make me more likely to hang onto the car.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
P.S.
screwfix sell a large spray can of penetrating oil for little money! But if it's cheap nasty stuff it may attack the rubber shackle bushes I always buy from a motorbike shop and check it says O Ring safe, (chain lube) Me too
Today I went to Central Morgan in Nottingham & back c 300 miles. I bought a red 2022 Plus Four so sadly now I have to part with my trad.
Posts: 2,064 Likes: 57
Posts: 2,064 Likes: 57 |
Welcome"John-streight4". 🥳
Enjoy you new car!
1 member likes this:
John V6 |
Today I went to Central Morgan in Nottingham & back c 300 miles. I bought a red 2022 Plus Four so sadly now I have to part with my trad. OMG ! Well, I didn't see that one coming John, enjoy !
Neither did I but fate intervened.
