1 members (+8Rich), 309 guests, and 29 robots.
+8Rich 93
John V6 49
Posts837,990
rockabilly john
5 Images
Leopold Offline OP
Leopold (shifter relocation & rebuild)
13 Comments
Leopold Offline OP
Inside of the shifter extension. One of these white plastic bushings should now be placed directly in the socket in the gearbox but I’ll be using a brass one instead to reduce play & extend life.
Leopold Offline OP
Here you can see the steel plungers on each side of the socket that bring the shifter back to the center (3rd & 4th gear) position.
Playing with shims/springs (accessed via the cover facing downwards) will change the center return force.
Leopold Offline OP
Leopold Offline OP
Example of the brass bushing I have on order. Easily found on Amazon or many Mazda sites.
