3 members (Morganmike, IcePack, nick w), 283 guests, and 47 robots.
John V6 69
DaveW 65
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Topics48,349
Posts813,091
Members9,212
aeroed, DJC, James Mc, JimWhin
stumog Offline OP
Could someone please advise me on flushing the water from the radiator.
All I can drain from the bottom bolt on the radiator is three litres of water and in the manual it says it holds 11 litres.
What am I doing wrong ?
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6
Audi A4 Advant (some blue colour not botherd)
It's possible that the drain hole is being silted up Stu. Or there's a hydraulic lock. Try removing the bottom hose, and that should allow better drainage. If it's a plastic radiator be gentle with it.
Open the heater valve and as Dave says remove the bottom hose.
The cap should be off on the expansion tank.
I have a spare plastic rad you can have for free if you collect it. It wasn't leaking when it came off my 3.7l Roadster
2025 MG ZS EV aka Trigger
If removing bottom hose doesn't work then try jacking the back of the car. Removing the heater feed bottom hose might help also by venting any lock since your car doesn't appear to have a heater flow control valve in keeping with the later 3.7.
stumog Offline OP
I have a tin of Rad Flush if I put that in the Rad and run the engine, would that solve the problem of the blockage
Possibly! But a back flush will be a good starting point!
Richard?
I am confused. Can you help me?
Isn't the normal goal when flushing (different from draining) to do so with the entire coolant system rather than merely a bit of it? Only draining the radiator
does not achieve much. That can be done be merely removing the top and bottom hose and using them with a hose to flush the rad. Even if only that
I prefer it to using the top cap (if one's rad still has one) and its bottom drain cock for the obvious reason.
One cannot flush a cooling system by merely draining the radiator..or even flushing it. Unwanted debris is as likely to remain in the engine, approximately
1/3 of the old coolant (and possible debris) remains in the engine. And of course, the engine cannot be properly flushed without removing, at least, the
thermostat. I pull the engine drain plugs as well. Is there some reason to flush only part of the system? The Ford Duratec 3.0 and method and all others go
much farther than that.
That being said, the right engine coolants now last as much as 100,000 miles depending on ambient conditions. Their technology has vastly improved in
the last 20 years. And digital coolant testers are very cheap (under 10 quid) and easy to use.
L.
P.S. Sadly, access to the Roadster thermostat is a PIA.
