0 members (), 329 guests, and 31 robots.
+8Rich 95
John V6 52
Posts838,016
rockabilly john
Page 26 of 27 1 2 24 25 26 27
SBP Offline
The 2012 onward Morgan Three Wheeler (M3W) Registry
(use the number under the right seat and the VIN (the last 3 digits) and not the number of the wooden frame)
under VIN
seat
0001 - xxxx - Feb '12 - Aeroman SOLD
0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK
0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO
0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO
0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO
0008 - xxxx - Jan '12 - Al1rhd
0009 - xxxx - Jan '12 - CSCC Sweden - DEMO
0013 - xxxx - Jan '12 - EX-1560 (sold in Belgium)
0015 - 2006 - Feb '12 - Malcolm M3W, 4th owner, acquired October 2021
0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ...
0027 - xxxx - Feb '12 - Tomtom
0032 - xxxx - Feb '12 - Herman01
0047 - xxxx - Feb '12 - Vitti4.3W
0049 - xxxx - Feb '12 - Asbojohn
0050 - xxxx - mar '13 - nadvys
0051 - 0051 - mar 12 Grimaud
0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods.
0080 - 2056 - Apr '12 - Jonathan G
0083 - 2048 _ Apr ,12 _ Elcyd
0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub,new chassis,Bleazey bevel box mount, 569 cams...Sold april 2021
0125 - 1002 - May '12 - John Winn
0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit
0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa
0131 - 0083 - Apr '12 - P964
0133 - xxxx - May '12 - MTW69
0139 - May 12 - Number42. The Bleazey Special. Every single upgrade to the latest spec. including chain final drive.(as at Oct 21) G56 Stage 1. Some sort of dark green paint with green upholstery and bright pack.
0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale)
0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling.
0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing
0200 - 0141 - May '12 - Simmo
0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen, Empire wishbones
XXXX - XXXX- aug 12 - X....TR6
0250 - 0240 - Sep '12 - french owner
0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS
0334 - 0213 - Sep '12 - HJP; April '16 - Tim W
0343 - 0305 - Oct '12 - hbatts
0350 - 0367 - Oct '12 - wis cos sold to Bobajobbob April 2021 - Replacement chassis, steel sprocket, urban cooling kit, comfort kit
0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride.
0385 - 0337 - Dec '12 - KBMOG
1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry!
0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA
0404 - 0399 - ??? '12 - Mikethetrike
0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch
xxxx - 0449 - Dec. 12 - Jm
0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018
xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________
0491 - xxxx - Feb '13 - CPC
0529 - XXXX - Jan '13 - MTWV2
Xxxx - 0474 - Feb '13 - Max - Superdry
Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings.
0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015
0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1
0554 - 0618 - Feb '13 - Karl K.
0579 - 0619 - May '13 - Laurens - Gulf Empire Kit
0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!!
0661 - xxxx - May '13 - PeteS
0050 - 0050 - May '13 - Naïves
0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort
0674 - xxxx - Apr '13 - DocNik
0680 - 0723 - Jul '13 - emiguy
14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket
0705 - 0725 - May '13 - Minnemog
0712 - 0793 - Jun '13 - The Seeker
0713 - xxxx - Jun '13 - The Austrian 2018 SOLD
0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark
0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU
0740 - 0782 - Jul '13 - CM31
0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed
0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit
27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator
0758 - 0855 - Aug '13 - Mol - SQUIRLZ
0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler
0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD
0856 - 0919 - Aug '13 - Black Adder
0859 - xxxx - ??? '13 - Zackybilly1
0877 - xxxx - Sep '13 - Smaug - Super Dry
0896 - 0926 - Sep '13 - Bigpoppapump
0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather
0905 - xxxx - Sep '13 - LarryS
0911 - 0906 - Nov '13 - Craig L
0915 Dec 13- George M
0921 - xxxx - Oct '13 - GT Tours Location
0946- HKNYMOG
0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune
0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen.
0969 - 1299 - Oct '13 - Swiss Ghost
0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory
1001 - xxxx - Oct '13 - Nippymog
0981 - 2179 - Apr '14 - spelunx
0975 - xxxx - Jul '14 - Owner Unknown vehicle in service
0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs)
1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16)
1152 - xxxx - Apr '14 - Lotusianer
1171 - xxxx - Apr '14 - alexuels
7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD
9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather
11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather
11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather
15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey
19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD
20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller
20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black
20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle
XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA
XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA
22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather
24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024
21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black
XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit
2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter
202001-84013 - April '17 - James Lyle-BRG w/Blk leather
202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W
202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA
32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA
24622-2011 - Jan '17 - High Noon - military matte green - honey leather
33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather
32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA
37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
202103 -1299 - December '17 Sports Blue/Honey Leather, Paul C Melbourne Australia
46080-2015 - April 2021, CraigL - Sport Sand w/honey leather, MMC Stage1, Texas, USA
0586 xxxx - Mar 2013 SBP
sold: Aeromax009/M3W/RoadsterV6/444seater
under VIN
seat
0946- HKNYMOG
SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Melbourne Australia
0586 xxxx - Mar 2013 SBP sold
M3W 2017 Sport blue.
SBP Offline
under VIN
seat
0946- HKNYMOG
0586 xxxx - Mar 2013 SBP - Grey
under VIN
seat
0383 - 2314 - Oct '12 - SMHM - UK car now in Germany near Munich - some upgrades, more to follow
0946- HKNYMOG
under VIN
seat
0946- HKNYMOG
SA9M3WV2EHP202103 (Australian ones have weird numbers) December '17 Sports Blue/Honey Leather, Paul C Adelaide, Australia
under VIN
seat
0334 - 0213 - Sep '12 - HJP; April '16 - Tim W sold Aug ‘18. Car recently rebuilt with new chassis by present owner and Bleazey centa mods. Tim W getting PEMBLETON V SPORT.
0946- HKNYMOG
under VIN
seat
0946- HKNYMOG
2027 - 2027 - Apr '16 - Feierstarter - Sport Green/Black Leather (SmallTransmissionTunnel by MorganPark), bought used Apr '23
2016 M3W
under VIN
seat
27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator SOLD
0946- HKNYMOG
under VIN
seat
0946- HKNYMOG
47054 - 2333 - Mar ‘15 - Metallic Orange/Black Leather
under VIN
seat
0706 - xxxx - Apr '13 - Kean - Superdry
0946- HKNYMOG
